Good Starter..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2003, 09:57 PM
Meangreen's Avatar
Good Starter.....
I am looking at replacing my factory starter on my 71 Chevelle and need some ideas. I dont know whats good and whats bad. The reason i need one is the one i have has a chipped tooth or something and every now and then it grinds when i try to crank it up. Ideas?
Old 06-17-2003, 01:39 PM
STARTER
What seems to be the problem might not be the starter.I had that happen some years ago and it turned out to be the flywheel. Pull the inspection cover and rotate it all the way around. Mark it with some paint so you can tell where you started. i think you'll find some damaged teeth on the flywheel.
Good luck Dave
