good wrench 350 cam upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-12-2013, 07:20 PM
Hi i am new to the forum, and a hobby hotrod guy. I build a 1965 nova and have some engine upgrade questions. the car has a stock goodwrench 350 crate engine with edelbrock intake and 600 carb, headers, and hei ignition, it has a turbo 350 trannie with 2200 rpm stall and shift kit, the rear end has 3.73 gears with auburn locker. the car hauls, it is a street car and a little fun a 1/8 mile track. some day i hope to to a head swap but for now I am trying to wake up the 350 a little more. I was hoping for some direction to a good performance cam upgrade base on all the other mods to car. i am thinking the cam used in the 290 hoarse 350 or doing another with sping replacement if needed. thanks
Old 04-12-2013, 07:25 PM
techinspector1's Avatar
Wiki Edits: 326
Please read through this camshaft advisory so that you will choose the best match for your motor based on the static compression ratio of the motor......
http://www.crankshaftcoalition.com/w..._compatibility
If you close the intake valve too early, the motor may build excessive cylinder pressure and detonate on the available fuel that you are using. If you close the intake valve too late, you will leak off so much cylinder pressure that the motor will be a dog. It's a balancing act.....
The Following User Says Thank You to techinspector1 For This Useful Post:
LATECH (04-14-2013)
Old 04-13-2013, 04:13 AM
thinwhiteduke's Avatar
Living In The Past
Very well said Tech. Clear , concise and simply easy to understand.
Good to see you back on deck the last few days! I was quietly concerned, hoping that everything was ok with you...
Welcome to the forum 65novablu , there's a lot of good, albeit sometimes divided, opinions and advice right here.
Duke
Old 04-13-2013, 06:10 AM
I bought a 350/290 HP crate engine for my truck and it worked fairly well. However, the truck is heavy, and I have a stock TH350, and when using it as a truck I needed more power at low RPM. I ended doing the opposite of what you want, and swapping back to a Summit 1101 cam that is similar to the one in the stock Goodwrench engine. Both cams worked well, but the original GMPP cam needed more rpm to wake it up so you might need a higher stall.
I still have the 290 HP cam somewhere (I just moved and the garage is a mess). Send me a PM if you might be interested.
Bruce
Old 04-14-2013, 09:49 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
If it's a roller the OEM cam we have used before which is still available from Summit is 14097395.Pretty decent low/mid response.
Don't like as a active commercial engine builder the shim head gaskets of .025 for street use.Rather deck the block/mill the heads to bring about the correct quench.The .025's don't have much bite in them and require special handling in the finish of the block deck.In any case,your trying to make a pc of coal in the OEM heads into a diamond where you can raise the SCR,but without having the flow numbers to match.Just like taking a bad situation and turning it into a worse one trading issues.
Remember.The one thing that is a constant.Not knowing if built correctly what your combo could have......................Then spent money on all the wrong things having to do a do-over costing even more!!.
Old 04-14-2013, 09:11 PM
1Gary's Avatar
Originally Posted by F-BIRD'88 View Post
If you were actually a active engine builder (or even a casual builder) you would know that the shim gaskets are .015" not .025"..
I have never had one leak or fail in 35 years, even with 12.60++compression. Even with nitrous.
Or on used blocks with far from idea decks.
Do not claim to be something you are not. No credibility. None of that made any sense anyway.
Gary you should really stick to your auctions.
Well if you would listen you wouldn't be 35 yrs behind.Your kind of advise ends up costing people MONEY!!!. Still you persist on this backyard B.S. with your at best a 13 second car.
Credibility??. You??. That's laughable.
This is a typical tactic when overrun with logic.To attack on a personal basis.
If you don't know,many have given up on you.Yeah I am crazy in that I still think there is something salvageable.In the meantime I just gotta make sure you don't hurt anyone.It's just the right thing to do.............
Old 04-15-2013, 05:58 PM
1Gary's Avatar
The advise stands.
What not to buy
http://www.cnc-motorsports.com/gaske...-per-pack.html
Old 04-15-2013, 07:51 PM
prostreet6t9's Avatar
Differential/Driveline
[QUOTE=1Gary;1666498] Still you persist on this backyard B.S. with your at best a 13 second car.
How fast is the car you drive?
Old 04-15-2013, 07:59 PM
LATECH's Avatar
F bird....and Gary1 .....come on guys......lets exercise some tact.
Everyone has a valuable opinion, lets being gentleman about it.
Slamming each other looks childish to other who read the post.
It also has no value to the thread. Lighten up.
Fact is stranger than Fiction
The Following User Says Thank You to LATECH For This Useful Post:
AutoGear (04-16-2013)
Old 04-15-2013, 10:59 PM
Interesting
Old 04-16-2013, 12:27 AM
1Gary's Avatar
[quote=prostreet6t9;1666928]
Been in a 9.90 car(s) for yrs.Fastest was a 8 second 1/4 car.Part owner with a driver wrenching on a 4.56@150mph car.
Old 04-16-2013, 12:36 AM
1Gary's Avatar
I totally agree with you.Honestly my heart aches for this first time O/P to have to run into this kind of thing.I really mean that from the bottom of my soul.
My reasons for it I think I have cover.I do hope we didn't lose this new member.
Old 04-16-2013, 08:46 AM
1Gary's Avatar
I don't like the shim style head gaskets.Not much bite in them and you really need to have the deck finish to handle/help seal them long term.
The Vortec engines have a head gasket issue in part because of less head bolts and in part because of the gaskets.I'm not sure if that isn't the reason why we are finding so many cracked used Vortec heads too.Thin castings aside.
Far and away better to machine parts and have the proper pistons for the proper SCR using a .039 head gasket.
The Vortec heads are ok performance heads,but do have their limits.Given what you have to do/pay to make them worth while,your far ahead of the game just to spend alittle more and get what you need from the aftermarket.
Old 04-16-2013, 10:03 AM
[quote=1Gary;1667053]
Nice! I see your in NY... Do you guys have the 10.5 & 10.5 radial classes ?
Old 04-16-2013, 04:35 PM
1Gary's Avatar
The edit should be less intake bolts.Sorry for the error.
I'm going to go back to what I said at first.Why the hell would you invest into anything that has a history of cracking??. Then cut them even more on a thin casting,then use a shim gasket.Just doesn't make much sense.
the Mr Good wrench 260 hp 350 for my money low_and_slow Hotrodding Basics 9 10-15-2011 12:27 PM
Cam upgrade for 350 Goodwrench david ahluwalia Engine 4 12-19-2008 01:38 PM
350 build upgrade cam azbandit Engine 14 06-17-2006 07:00 PM
350 build upgrade cam suggesstions. azbandit Engine 2 02-07-2005 07:23 PM
