Goodbye American Chopper. - Page 6 - Hot Rod Forum : Hotrodders Bulletin Board
  #76 (permalink)
Old 01-03-2013, 11:50 AM
Originally Posted by malc View Post
Didīnt early choppers "jacknife", front wheel over turning ?
So what happened to make them safe(r) ?
Yes, this was before a way was found to return the trail distance and positive/negative direction to something that was managable. The early bikes simply angled the steering head and used long forks. This resulted in big and often uncontrollable steering problems by upsetting the distance and direcction between where a line drawn along the fork would enter the pavement and where a vertical line from the pavement thorugh the axle occurs. The solution was to also angle the forks by changing the pitch of the upper to lower tripple tree. Doing this kept the radical chopped and raked out look of the front end but put the true angles and distance between the theoretical point of fork rotation and the actual point of tire contact with the pavement back into the managable range of a positive 4 to 6 inches.
Bogie
The Following User Says Thank You to BogiesAnnex1 For This Useful Post:
malc (01-03-2013)
goodbye cruel world! unclebill Off-Topic 7 12-08-2012 10:00 AM
American Chopper build off Bad Rat Hotrodders' Lounge 21 12-12-2011 04:16 PM
Goodbye corvettes! BarryK Hotrodders' Lounge 43 06-12-2011 10:15 AM
Goodbye Nightrider Hotrodders' Lounge 7 02-26-2005 07:45 AM
American Chopper, the Christmas bike episode hotwheels55 Hotrodders' Lounge 23 12-29-2003 03:22 PM
