Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - goodmark hood fit ? on 78 malibu
Old 05-29-2012, 04:20 AM
deadbodyman's Avatar
deadbodyman deadbodyman is offline
Wiki Edits: 11
Originally Posted by heathj1
Bought 2" cowl goodmnark hood from summit got it not dents looks good. Put it on and the back corners under the hinges the hood stick up 1/2 in on drivers side and about 3/8 on passenger side. I adjusted hinges as down as low as I could and it still look crap. Am I going to have to try to modify hinges some how? Dont they fit better then this? Makes me want to put on stock hood and go after it with a jig saw.
I make my own cowl hoods its not hard and I can show you how if you can get your money back for that one...Basicly you make two cuts down the length of the hood and a cut in the back leaving the front intact.then pull the strip up and slide a wood form in between then lay the strip back down screwing it to the form and giving it its shape then you just make the sides and weld them in.but you gotta be pretty handy with a welder...
