goodwrench crate motor/ cam question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-09-2003, 08:33 PM
firestone's Avatar
http://teamrfc.gospelcom.net
Try calling these people:
http://www.gmpartsdepot.com/crate_motor.htm
Or these people:
http://www.gmgoodwrench.com/
Or these people:
http://www.paceparts.com/store.asp
I have no idea if these people will be able to help you at all, but it is a place to start at least.
Good luck
Adam
  #17 (permalink)
Old 12-09-2003, 11:28 PM
http://www.sdpc2000.com/cart.asp?act...d=877&pid=8336
I'd expect the springs to be these (pn 3911068) or equivalent. Same as they used in most all SBC's from the late 60's through the 70's & even into the late 90's on some. GM used them with valve lift up to .460", but the cams had gentler ramps compared to modern aftermarket stuff, so I'd change them to whatever your cam maker recommends.
  #18 (permalink)
Old 12-10-2003, 04:29 PM
72chevy240z's Avatar
I called summit tech line and they said with the sumk1104 cam I should get these http://store.summitracing.com/partde...1515&view=1024 springs rated at .490 max lift so I did. Only 43 bucks.
Whats the best way to install the springs with the heads still on the car? With the rope trick or the air trick. With the air trick what and where do i get the valve to put the air in the cylinder. Give me all u know about this. I don't want to mess it up. And any tips on the cam too. thanks for all your help, bob
The compression of the stock crate motor of 8.5..will this be enough for this cam?
  #19 (permalink)
Old 12-10-2003, 05:47 PM
Auto-Part's Avatar
Comp Cams 268.
Edited for offensive language. willys36@aol.com
  #20 (permalink)
Old 12-10-2003, 05:53 PM
lluciano77's Avatar
Don't use the rope trick. I had a keeper that was stuck in the retainer and I wanted to change it with the heads on. The air compressor wasn't enough to hold the valve closed. I decided to use the rope trick. The rope got stuck in the chamber. I eventually got it out but the valve must have cut a piece of the rope off. It was left behind in the chamber. I ended up with a full teardown to fix a bent piston. If you can't do it with the compressor then take the heads off.
  #21 (permalink)
Old 12-10-2003, 05:58 PM
Ok thanks for the tip about the rope.
The guy at summit said the springs I mentioned above would require no machining of the head and I could use the stock retainers, is this true?
  #22 (permalink)
Old 12-10-2003, 06:07 PM
Grant209's Avatar
do you got anymore tips on how to change the valve springs with the heads on the engine with an air compressor....because soon i will be changing my cam and i want to change my valve springs too....thank alot in advance.....
  #23 (permalink)
Old 12-11-2003, 03:46 AM
Frisco's Avatar
Glad To Be Here
Screw-in adapters are sold thru Summit and Jegs and others. I made my own by removing the core from an old spark plug and silver soldering a quick dis-connect for the air line. I set the regulator on my air compressor to 125 psi and everything worked fine. Be sure that the piston in the cylinder you are going to apply the air to is at the BOTTOM of its stroke before applying the air. The air will rotate the crank otherwise. If the pan is off when applying the air you will hear air leaking. This is 'normal' and should be no cause for alarm.
  #24 (permalink)
Old 04-06-2004, 05:37 PM
hey guys i just bought the 10066038 targetmaster block too, was wondering if anyone had any stock specs for this engine. cam, heads, valves, hp , torque
i looked everywhere and couldn't find anything, i wrote goodwrench and they told me it was the same as the 350 LM1 is this true?
thanx
  #25 (permalink)
Old 04-07-2004, 01:00 AM
Yep.
  #26 (permalink)
Old 04-07-2004, 07:14 AM
Rhansen's Avatar
Footbraker
I'm going to stick my neck out here and say that is too much duration for 8.5:1 CR. The motor will have little or no bottom end, I'd recommend another point of compression before using that much cam. Use 270 or less adv. dur and you should have more useable power. (I tried a similar cam in an 8.5:1 motor and it was a dog below 3000 rpm, changed to a 267 adv. dur. and was MUCH better, according to DD 2000 the smaller cam was worth 30+ hp and tq.)
