Goop sealing interior welds? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2003, 11:18 PM
327ImpalaSS's Avatar
Post Goop sealing interior welds?
There's a tar like substance sealing all the welds in the interior of my 68 impala. Should I wait till I por-15 the interior before I reseal the welds (it all flaked off) or should I reseal them first? Also, what shold I seal it with? Silicone?
Old 02-13-2003, 11:26 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
That substance is called "seam sealer" and no you should NOT seal them before the por 15. Exstensivly clean all that goop off and aplly the por-15 over the seam as well as the rest of the floor, it will seal it. Use two layers over the seam to be sure.
HK
Old 02-13-2003, 11:30 PM
Post
Cool, thanks HK.
Who woulda guessed it was called 'seam sealer'?
Old 02-15-2003, 05:31 AM
joe k's Avatar
Post
I used a product from 3M called heavy duty drip chek sealer #08531.Worked good and dried fairly fast in cold temps,better than silicone.
