Gorrilla Glue - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-08-2005, 08:58 PM
Derkyb's Avatar
Gorrilla Glue
Has anyone used this stuff? How does it work?
Old 11-08-2005, 09:46 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
It is the best and strongest glue for woodworking that I have ever used.
Old 11-09-2005, 01:33 AM
techinspector1's Avatar
Wiki Edits: 326
Has worked well for me attaching rubber moldings. We used to call it gorilla snot.
Old 11-09-2005, 08:53 AM
WakBordr7387's Avatar
Gone fishin'
Last journal entry: blah.......again
Wiki Edits: 2
Excellent stuff, It takes a while for it to set though, and you have to be careful to not use to much. It expands alot when it dries and Ive had it drip alot before.
Brad
Old 11-09-2005, 12:04 PM
sicksixseven's Avatar
Ground Clearance Is Over-Rated
One word: amazing. It does expand, but it is by far the strongest and most expensive glue I have ever seen. I have used it for everything from building a fishing rod rack, to fixing a chair, to gluing down vinal to sealing holes on ym truck. Very good stuff. Sam.
Old 11-09-2005, 04:24 PM
302 Z28's Avatar
Excellent stuff, especially for wood working. When I was building and flying radio controlled airplanes we used it for bonding balsa wing skins to foam wing cores. Way stronger than epoxy and a whole light lighter. We took advantage of it's expanding qualities. It also helped to moisten the surfaces with a light water mist, really causes it to kick.
Vince
Old 11-09-2005, 04:31 PM
All of the above, Simply amazing stuff to put it mildly! It's nice to find a product that is everything it claims, It is that and more.
Old 11-09-2005, 04:44 PM
Derkyb's Avatar
Used it last night and everything stated above is true this s&&t is amazingly strong. Used it to repair a dash where I had to drill through the repair held like the original plastic.
Gorilla Glue is from Aliens Native Gearhead Garage - Tools 13 08-17-2007 01:58 PM
Glue for running board rubber cboy Body - Exterior 13 02-05-2006 06:50 PM
Cleaning Tire-Seal Glue Off Of Alloy Rims nightrain_rod Body - Exterior 4 01-30-2004 07:58 PM
best glue for mirror to what looks to be plastic? bullheimer Body - Exterior 5 01-25-2003 09:42 PM
Hot glue solvent 4 Jaw Chuck Hotrodders' Lounge 8 09-19-2002 05:57 PM
