Got 2K primer on the windshield - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-24-2011, 01:21 PM
I got some 2K primer on the corner of the windshield, it doesn't want to come off. Tried lacquer thinner, razor blade, ultimate glass cleaner(like polishing compound) still there.
Help!
Old 05-24-2011, 04:46 PM
deadbodyman's Avatar
Wiki Edits: 11
might as well paint it too...try some paint stripper first though..and a razor...be more careful it can get worse ....5.00 a roll for good masking tape IS rediculus but when they got you by the short ones ,they got you.,,buy good tape and masking paper...
Old 05-24-2011, 10:59 PM
I new razor blade will take it off with minimal effort. Be careful not to scratch the glass with the edges of the blade. A bit of soapy water helps.
Epoxy Primer, Urethane Primer Compatibility brimcp99 Body - Exterior 7 11-22-2010 07:04 PM
Etch Primer SUCKS? Use epoxy primer? Arizona El Camino Body - Exterior 14 10-22-2009 08:51 AM
Epoxy Primer & 2K Urethane Primer acquadigio79 Body - Exterior 17 08-15-2009 04:07 PM
Epoxy Sealer-Primer With 2K Build Primer on top kilgorq Body - Exterior 4 04-29-2008 04:30 PM
can i spray epoxy primer over etching primer without sanding? wickiewicked240z Body - Exterior 1 08-29-2006 09:07 PM
