got the 350 out with a surprise - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-11-2008, 01:11 PM
72 grabber 51F-1 65 chevystang
I have been working on the 350 in the 63 C-10 for a couple weeks. About 3 days ago I decided it was time to remove the motor and tranny. Monday I unhooked the motor mounts, removed the radiator and hoses. I woke up at 5:30 this morning and decided to work some more. I removed the manifolds, and crossmember. I got the engine puller hooked up and decided to take a break. I came in and was on the computer and dad says if I take the hood off the motor would be out. He had it almost out but it was hitting the hood. I went out and we took off the hood. It was out in about 5 minutes. I need to put a freeze plug in it. The good news is the turbo 350 has been rebuilt. I wanted to use the powerglide but since this tranny is rebuilt I will use it. Here are some pics
Old 06-11-2008, 03:15 PM
Holder350's Avatar
Auto Parts Professional
To hot to be workin on that chit.....
Its like 105 most days here in Tenn. Cant imagine what it is down there.
Cant say too much I put a head on a 97 F250 one summer....that I shall never do again....not with it in the truck!
Old 06-11-2008, 05:50 PM
I know the heat sucks. I was about to call it a day at 10:30. I had came in. I was on here and dad had had lifted the motor almost out. So I went out and finished. At about 4:00 we moved it into the garage. My 69 F-100 has all black interior so being in it for 5 minutes in the yard will roast you. It was on the back property so I put it in the bed and hauled it to the garage
Old 06-11-2008, 06:23 PM
another picture. We just lifted it out of my truck into the garage
Old 06-11-2008, 07:09 PM
schnitz's Avatar
Last wiki edit: Building a new shop
Last journal entry: Christmas 2008 came early!!!
Wiki Edits: 54
Extreme cold is bad too. I had to change the camshaft in my '78 Monte when it was about minus 15* back almost 13-14 years ago. Have a pot of coffee, work on it for 5 minutes, another pot of coffee....yadda, yadda. Living on a windswept ridge and without a shop to work in sucked.
Anyways, looks good seeing it out, doesn't it?
In a while, Chet.
Old 06-15-2008, 05:54 AM
31 five window
Last journal entry: grill and rear end
Looking good. Never put a powerglide in a truck that heavy for high performance. The TH350 will definitely work better.
Old 06-15-2008, 06:07 PM
460beast's Avatar
FORDGUY
i have done 2 engine swaps and a tranny swap over winter in my friends back yard. here winter is cold and wet. I would take heat over cold and wet any day.
Old 06-15-2008, 07:46 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I use to live in Ohio, moved to Florida and it will be a cold day in.. well Ohio before I move back
Old 06-15-2008, 07:55 PM
MrPhotographer06's Avatar
Army Strong
Last wiki edit: How to remove a VW Type I body
Last journal entry: well once again
good job on getting it out.. is that truck lb or sb?
Old 06-15-2008, 09:07 PM
it's a longbed. The truck isn't much count. The floors are rusty. Both front fenders have tons of bondo in them and big rust holes. When I was taking out the tranny crossmember I realized some of the cab braces were rusted. The frame is broke off behind the rear wheels and there is no bed floor. The bedsides are bent up too. I put the truck on craiglist for $250 and a junkman offerd me $175. Needless to say dad will take it on its last ride in a day or 2. I traded dad this body and 2 maverick hulls for the 48 wrecker in my gallery
Old 06-16-2008, 02:02 AM
460beast's Avatar
FORDGUY
you know what they say about ohio weather. if you dont like it... move south. lmao
Old 06-16-2008, 08:04 PM
Army Strong
ha.. wow weve still got ours.. check my gallery
Old 06-16-2008, 08:21 PM
while cleaning out the cab I got another suprise. About 4 or 5 years ago my uncle gave me and dad a 4 barrel holley carb off a bus. It had got stuck in this truck a while ago and I had forgot about it. I saw a carb in a bag and I figured it has just another junk quadrajet. I pulled it out and realized it was a holley. The only bad thing about it is that it has a governer because it was off a bus. Now I have a holley carb for the maverick when I go to build it
Old 06-17-2008, 04:15 PM
last ride
here are some pictures of the 63 going on its last ride.
all loaded up
http://www.hotrodders.com/gallery/da...dium/00214.jpg
the fenders only have minor rust
the bed only needs minor alignment
something minor's missing like the back frame
Old 06-17-2008, 07:43 PM
Army Strong
how many cracks does the glass have in it?
Port or Full time vacuum cool rockin daddy Engine 129 10-05-2010 03:00 PM
Cam/Lifter Question about Ramjet 350 Jake Harsha Engine 20 07-07-2010 06:22 AM
DEBATE: Which heads are better?....Chevy 350, Pontiac 350, Olds 350 or Plymouth 350. Steve-0321 Hotrodding Basics 21 11-26-2007 12:44 AM
305 head on 350 savman1 Engine 4 10-15-2006 09:18 PM
348 or 350 delimma 62ImpalaSS Engine 12 05-17-2006 11:03 PM
