Got the base down, slight orange peel, what to do before clear? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2008, 05:28 PM
I've got the base down on my 56. The base is actually a SS made by Kirker. I plan on clearing it for added gloss and durability.
I've got slight orange peel in the base. If I clear it, then cut and buff the clear, will the orange peel show through?
Since half of it is a solid red, I could easily block it down flat, but the other half is metallic so if I go sanding on it, I'll have to reshoot to get the metallic particles evened out.
what would ya'll suggest?
Thanks,
Shad
Old 08-13-2008, 05:55 PM
scrot's Avatar
Isn't it a moot question?
Since it'e SS urethane, wont you have to sand it down with #600-#1000 before shooting on the clear?
Old 08-13-2008, 06:26 PM
Not that I know of. I've never heard of that, unless you go outside of your recoat time window.
Old 08-13-2008, 07:23 PM
scrot's Avatar
Correct. The recoat period is 18 hours. I just looked it up.
http://www.kirkerautomotive.com/images/PDF/ULTRAGLO.pdf
Better get busy.
Old 08-13-2008, 09:03 PM
Thanks,
So will the orange peel show through if I clear over it, then cut and buff the clear?
Old 08-13-2008, 09:21 PM
Originally Posted by shad9876
Thanks,
No it wont.
Old 08-14-2008, 04:49 PM
scrot's Avatar
Hey
what did you do?
Clear peeling right off of base color cyclopsblown34 Body - Exterior 22 11-28-2007 08:13 AM
How to spot repair base coat? formula_pilot Body - Exterior 3 04-15-2007 08:53 AM
Orange Peel and baking Fozzyber Body - Exterior 16 11-25-2006 08:36 PM
Base And Clear PAS55 Body - Exterior 14 09-30-2005 08:45 AM
primer orange peel help jerrylo Body - Exterior 11 10-28-2004 05:52 PM
