got crank ground but what size?
The mains measure from 2.631-2.636 and the rod 2.095-2.104.
The rods seem std but are they?and the mains seem to be. 020? |
What would measurements be if the rod journal was turned. 010 and the main turned. 020 and 030?
Ok had it checked.mins are 2.633 on all mains and rods are 2.087 on all.
Digital caliper with points
std is 2.0990 / 2.1000 & 2.6484 / 2.6493, 5th journal is 2.6479 / 2.6488
So your crank is 010 / 010 If you question the caliper have the grinder or shop mic it for you. As said before your grinder or shop should have supplied the correct bearing set. When reassembling you can check it with this. Plastigauge - Plastic Precision Clearance Gauges |
Std main is 2.650 And mine measure 2.633 so its. 020
Std rod is 2.100 and mine measure 2.095-2.104 so its std. Am i right about this |
| ground 400 crank or new 383 crank? | backyard71nova | Engine | 10 | 09-12-2007 06:13 PM |
| SBC small j crank to 350 size? | Haulin327 | Engine | 5 | 05-26-2007 12:32 AM |
| crank shaft size. | Ben.T | Engine | 1 | 05-09-2007 01:16 PM |
| crank thread size | Ruha | Engine | 9 | 03-01-2005 06:13 AM |
| Crank Size | Thom Laybourne | Engine | 10 | 04-28-2004 04:30 PM |
