it sounds as if the rocker arm lock nuts are backing off once the engine runs for short time and gets hot. this is common on older small blocks, I would suggest going to the junk yard and getting a set of lock nuts off a newer small block, new as you can find. I had this problem years ago, after I would adjust the rocker, I would watch the nut back off as the rocker moved. we also had this same problem when we bought a set of cheap summit rocker arms that came with lock nuts, they backed off as soon as the engine got hot. most parts stores won`t carry the lock nuts seperate, they only come with a replacement rocker arm.
Classic symptoms of a failing cam. Tell us about the break in you did.
Chris |
Should be able to buy new nuts about anywhere. Try your chevy dealer. Or try a jam nut. Time it before and check it after.
Troy __________________ If you don't make mistakes. your not doing anything. 69 ss rs full custom camaro 98 ISCA grandchampion 69 ss rs bb camaro wifes driver 66 Elcamino 350/all dz parts,ac,windows,loaded,my driver 69 ss chevelle bb conv.fresh frame off 26 T sedan street rod |
Studs
You may want to lay a straight edge across the rocker studs, if they are pressed in. Higher lift cam can lift pressed studs sometime. They may be uneven indicating movement and requireing readjustment.
nevermind i wasn't adjusting the rocker arms correctly. i got it running a lot better but it is still pretty sluggish, the point underneath the distrbuter cap is shot though, could this be a problem with it running like poop?? nah it's got enough power, i can beat a lot of people, it better not be the cam i just replaced it with a racing cam.
61CheyTruck,
Glad to hear you got it running better. We hope it isn't your cam too but sometimes people will let their engine sit and idle for a long period of time when they should be keeping the RPM's up to around 2 grand so oil can be slung all around in the engine. I think most cam companies have their own break-in steps and you need to follow them "to the letter" or the cam might go flat and then the company say "So sorry, you didn't do as we told you to do." And they will not replace the cam. Keep twisting the wrenches, and Have Fun. Scholman |
yeah i obviously still have some tuning cuz it's still backfiring pretty good, it has died on me about 2-3 times when i come to a stop, nothin too bad, it seems to lack power in the higher rpm range, doesn't have the power it did before the head gasket blew, but hopefully it's gonna get better with some fine tuning.
Exhaust valve to tight or timeing way off.
