Got her Running......BUT - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-08-2004, 01:21 PM
ma2gardner's Avatar
Well I have gotten my 53 Lincoln 317ci running fairly smooth. But when I put it into gear it trys to die out. I have to pump the gas to get it going. I can't seem to find any vacume leaks or such but I may be missing them.
What can cause this problem. Trys to stall out in reverse and forward gears.
Thanks,
Jimmy Gardner
Old 01-08-2004, 02:07 PM
Siggy_Freud's Avatar
Am I mistaken or do some vehicles have to different settings for park idle and running idle? I could be totally off the mark but if I infact due have a clue then that might be your problem.
To find a vaccum leak try spraying carb cleaner (or if you have it propane) around the engine compartment and that should allow you to hear the leak as the engine idle will kickup a bit if you find the leak.
Bringing history and technology together.
Old 01-08-2004, 02:46 PM
Thom Laybourne's Avatar
Care
Ouch. Be careful with those substances around the engine. Plain water with a little soap goes a long way. Water has oxygen and the engine will COME ALIVE if the water gets inside. The water will also be heavy enough to close (temporarily) a leak. A car in park idles faster because there is no load. Put it in drive or reverse and the tranny engages putting a load on the engine causing it to slow down. Set the idle up around 1100 and try the water. Seems to me those old Lincolns use to run a bit rich and idle about 900-1000 in gear. Nice car.
hr41pearl
Old 01-08-2004, 02:48 PM
lol using water takes out all the fun though. I enjoy putting on my bomb squad gear and doing a little mechanic work but I guess thats just me.
Old 01-08-2004, 02:53 PM
Responsible
I am sure there is humor there. However, someone might take you serious and do that. If they get hurt....... well there are better jokes.
hr41pearl
Old 01-08-2004, 03:01 PM
Yeah I realize that. However the carb cleaner and propane have worked well in the past. If your not going to do something carefully then you shouldn't be near an engine at all. In the future though I will watch what I say when it pertains to potentially dangerous advice.
Old 01-08-2004, 03:22 PM
Thanks.
Hey, it might be one of my daughters asking the question. hehe
So what is your ride of choice?
hr41pearl
Old 01-08-2004, 04:21 PM
poncho62's Avatar
Wiki Edits: 5
Re: Care
hr41pearl
Where do you put the water?, whenever I poured a little down the carb, all it wants to do is die........
Ontario Rodders
Old 01-08-2004, 04:29 PM
Spry Bottle
Just the end of my garden hose. Na. I have lots of little spray bottles around. Work well for many things.
hr41pearl
