Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Got a Lokar shifter? Check the nuetral safety...
Old 04-18-2013, 06:36 AM
Irelands child's Avatar
Irelands child Irelands child is offline
Amazingly, there are many thousands of Lokar shifters with absolutely no problem. What I am saying is before you complain about a company you at least have done: one, (re)check YOUR adjustment after saying that you have been working on this vehicle and I'm assuming that the shifter was installed, check for damagetwo, bench test the switch, three (re)check your wiring, four call Lokar. As far as adjustment being difficult - be serious - there's a threaded plug you screw in in place of the NSS to set it. It takes ten/fifteen minutes.
Irelands child
