Got a Lokar shifter? Check the nuetral safety... - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-20-2013, 07:53 AM
OLNOLAN's Avatar
Faux pas
Brian, Shh.............it happens, if you laugh about it, the pain will ease. Made me think about the time I nearly knocked the door of my old camino. Add it to the Faux Pas thread. Nolan
Mechanical Faux Pas
  #17 (permalink)
Old 04-20-2013, 09:39 AM
Last journal entry: T'Bird projectr
I'm already able to laugh about it, although there WILL be a picture of it on my "wall of pain", and there will never, EVER, be another Lokar product in any of my cars. I fully accept responsibility for turning the key while not being behind the wheel, but I accept no responsibility for the nss not working. These need to be bullet proof, idiot proof to install, and should require ZERO maintenance.
  #18 (permalink)
Old 04-20-2013, 01:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Tech forums are for posts with tech items. Non tech posts are removed
The Following User Says Thank You to Crosley For This Useful Post:
OLNOLAN (04-20-2013)
  #19 (permalink)
Old 04-20-2013, 01:58 PM
OLNOLAN's Avatar
Oh, So that's what happened to the first one.
Mr. Crosley, Just trying to make my friend Brian feel better about the whole situation by injecting a little humor. My original post was not technical either, so you can delete it too.
Mr. Nolan
  #20 (permalink)
Old 04-22-2013, 09:52 PM
Sorry about your accident. Cars can be fixed though. I also have a trans mounted lokar and no matter how I adjust it it will start in P, N and OD. Obviously it's not good to have it start in OD, but I am aware of it and I'm the only one who drives it. Only time the key gets turned is with me sitting in it with a hand on the wheel and a foot on the brake. It is on my list of things to address eventually, but it is a ways down the line.
I read a post somewhere about somebody installing a very thin shim between the switch washer and the mounting boss. I tried it but then it would not start at all. Maybe it wasn't thin enough.
  #21 (permalink)
Old 04-23-2013, 08:12 AM
RatPin,
Write to Lokar. That's what I've done, although I've had no reply as yet. I don't expect anything from them, only that they address this evidently very common failing of their design. It's inexcusable.
  #22 (permalink)
Old 04-23-2013, 08:41 AM
302 Z28's Avatar
There is no problem with a Lokar shifter and the NSS there are literally thousands in use around the country. I totally agree with IrelandsChild, get real you just screw it in and its done, check its operation and its good to go.
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
Crosley (04-23-2013)
  #23 (permalink)
Old 05-07-2013, 07:56 PM
496CHEVY3100's Avatar
Built Not Bought
Last journal entry: 53 ad3100
Mine is a th 400 instead of using shims check the set screw in the side to side spacers ,the instructions says 1/8 in clearance ,I read them AFTER mine would start in gear,
  #24 (permalink)
Old 05-07-2013, 08:04 PM
Which spacers are you referring to?
  #25 (permalink)
Old 05-07-2013, 08:16 PM
Built Not Bought
mine has two round plugs that slide in a recessed hole on each side of the transmission with set screws to hold them in place,then the cradle bolts to transmission tail shaft,and 2 small set screws 1/4 in.on top po keep it in place, mime is a th 400 with a 18 in vintage style shifter.
  #26 (permalink)
Old 05-07-2013, 08:19 PM
I remember the spacers that go in the holes on the side of my 700R4, but I don't remember any set screws. I will have to check.
  #27 (permalink)
Old 05-07-2013, 08:25 PM
Built Not Bought
the set screws I am referring to go straidht in the side ard fit into the cupped part, with a locknut to hold them in place if you left 1/8 in without locknut they would not stat tight.
  #28 (permalink)
Old 05-10-2013, 11:55 AM
lokar neutral safety swith.
I to am having trouble adjusting the safety switch on the Lokar shifter. Not happy with it at all. I have tried their way and all kind of ways does not work. However, I can make it work it will take me modifying the shifter so that it will work, it will start in Park and Park only. Lokar makes a good quality product but the neutral safety switch adjustment for a 700R4 does not work. I came here to see if there was an answer. I see I am not the only one who has a problem.
Thanks
Ranrodder
  #29 (permalink)
Old 05-10-2013, 01:45 PM
Built Not Bought
Are you using the one that screws into shifter or the one that attaches to a shifter rod ,the one on the rod seems to work best ,can be used for NSS or back up lights.
Lokar Shifter kmac-1 Transmission - Rearend 5 08-26-2007 08:37 PM
Lokar shifter instructions supermankbk Transmission - Rearend 9 07-06-2006 06:49 PM
Lokar Shifter Bell Crank bartamos Transmission - Rearend 0 06-01-2006 11:41 PM
C-6 Nuetral safety switch rewire jagr1234 Transmission - Rearend 3 08-05-2004 01:08 PM
700R4 w/Lokar shifter help 39chevy Transmission - Rearend 2 03-31-2004 04:49 PM
