Got new 350 tranny, how to check it out? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-29-2005, 01:53 PM
rwruther's Avatar
Last journal entry: new wires for the hot rod 39
It cost me 80 bucks, it has no torque converter and it leaked fluid all over my leg when I moved it out of my truck to the garage..... seems there is a big hole where the dip stick goes, and two others for the tranny cooler.... I guess.
How can I know if this thing actually works?
Thanks and Hello Tom, (the only other guy with a 39 Pontiac coupe on this bbs)
R
PS I don't want to put it in and try to drive away... I'd like to check it first... if it's dead, then I'll go buy a working 700r4. If it works, then I can either put it in and drive for a while, or sell it and use the bucks to buy the OD jobber a? Or buy the wife a hat? (just kidding) (Wife already has a hat.)
Old 03-29-2005, 03:35 PM
STUPID is as STUPID does...
Unless someone in your area has a tranny dyno the only other option short of installing it is to take it to a trans shop and have them pull it apart. That'll cost you money that you could be putting into a 700R4. I think you realize this but that TH350 is really not the way to go. A 700r4 gets you so much more for your buck that TH350's are pretty much a throwaway trans anymore.
Mark
Old 03-29-2005, 04:39 PM
BOBCRMAN@aol.com's Avatar
What color was the fluid and how did it smell. It should be red and not smell burnt. Also grab the input shaft and check for excessive end play (In and out). Same goes for the output shaft. Pull the pan and look for aluminum or steel particles in the pan. A very small amount is normal. A lot means. BOAT ANCHOR>
80 vette tranny.. what swaps with the stock 3 speed in the 350? jens42 Transmission - Rearend 2 08-26-2003 07:55 AM
Tranny Questions JRS1967 Transmission - Rearend 1 08-24-2003 12:01 AM
Tranny fluid heating up engine??? black66 Engine 1 07-13-2003 09:18 PM
88 AOD tranny problems rflud Transmission - Rearend 9 02-17-2003 04:53 PM
Will a 5-speed pontiac tranny hold up to a 350?? chevyelc81 Engine 4 05-24-2002 07:20 PM
