Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Got new intake should i ditch the carb spacer??
Old 10-04-2004, 01:30 PM
DoubleVision's Avatar
DoubleVision DoubleVision is offline
I`m kind of confused by your post. If you were running a edelbrock carb on a stock intake, then you had to have a adapter to make it work, was it a 4 hole adapter or a open adapter? if it`s a open adapter the best place for it is in the trash, these disrupt the flow as well as the vacuum signal, if it`s a 4 hole adapter, set it aside, as you don`t need it on the Performer intake, if it`s just a plain 4 hole carb spacer, then I would keep it on.
