Got new shifter problems
Well i finally got arround to swaping out the broken shifter cable in my 71.
I went with a beefier racing series cable from B&M for their megashifter. Problems right from the getgo, the hole i cut in the floor to make it fit was a bit too small, and the cable was way too rigid to make it work, so i widened the hole a bit not much of a problem there. The cable is again too long the stock one was 5 ft and it was looped under the car to make it fit, so i ordered a 4 ft length.. still much too long, so i just say screw it and loop it again (i know itll wear out faster). The pull on it is just a bit shorter than the last one so when i went to mate it to the tranny i used the hole on the furthest left like the instructions told me to. Cable wouldnt reach... Screwing arround with that little end cap thing with the codder(sp) pin in it i got it to reach by pulling the lever on the tranny just a bit towords the shifter and then sliding the thing into place. But now the end piece for the cable is only holding on by like 4-5 threads. Finally after screwing arround with the nuts i got it to work just barely. SO i take it for a test drive, shifts a bit hard into reverse, neutral is a ton easier, drive works easy as well. Downshifting from 3-2-1 manually is ok until you get to 1, it makes a not so pleasant noise kinda like a grinding/whining noise almost, very hard to discribe. Cant hear it at all in 2-3 just 1 when shifted manually. What could it be? any idea? teanny is a th400 Ill try to make a picture of what im talking abot with the end cap thing with my awsome MS paint skills....
Sounds to me like the detents in the shifter mechanism are not in sequence with the movement of the shift arm. Drive and 2nd must be lined up fairly close but in 1st it sounds like you are not fully engaging the tranny. Try this experiment, put the car in park and pull the cottere pin on the end cap. The end cap should easily slide in and out of the hole on the trans shift lever. With the "end cap" still detached, move the shift at the console to 1st gear and then manually move the shift arm on the tranny to low. Then see if the "end cap" slides easily into the hole on the shift arm. If it doesn't, then you need to adjust the end cap (screw it in or out) until it it easily slides in the hole. Then repeat the above process (disconnecting the end cap each time) and shifting back into Park - and recheck the fit. You need to fine tune the position of the end cap on the cable end until it easily slides in and out the trans shift arm hole in both park and low. In some cases this will require re-positioning the cable where it bolts to the trans pan. Once you have it correct at both ends of the "throw", all the gears in between should engage properly.
Always learning...and sharing what I've learned. The Scratch-Built Hot Rod. |
Is it a problem if the threaded end only goes about half way through the endcap?
Yes it is mounted to the trans with a bracket, but there is 0 slack in the line, i needed to adjust it all the way to one side just to get the sheathing to reach the mount on the shifter.
And yes the cable is mounted on the backside of the shifter(side twords the trans) but again with the cable being thicker i wasnt able to properly slide the cable into the little groove cut into the mounting plate thing, but it IS bolted to the correct spot and dosnt slip off at all. This setup will probably only have to last me through the summer, because then i will be putting a factory repro console/shifter in. |
| Engine Problems, Oil related or coincidence only? | Francis | Engine | 1 | 05-12-2004 06:56 AM |
| Name that shifter?? | EricTopless68 Camaro | Transmission - Rearend | 6 | 05-08-2004 02:31 PM |
| Automatic shifter in pickup floor? | newchevyman | Transmission - Rearend | 5 | 09-02-2003 06:48 PM |
| 5 speed tranny with forward shifter? | Warm_Spit | Transmission - Rearend | 2 | 08-13-2003 08:09 AM |
| Ratchet Shifter problems | Croz | Transmission - Rearend | 2 | 02-07-2003 05:27 PM |
