got a pounding HEAD ache!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2013, 08:18 AM
ok, first, i'll take the butt kicking and hand slaps. i'm going to ask something that i'm sure has been covered, but after days of searching multiple forums, i haven't found an answer.
first. the setup.
350 .030 over, near zero deck (I measured .006")
flat top speed pros with 4 valve reliefs.
fel pro head gaskets 4.060" bore .039" compressed
comp cams xe262h 218/224 @ .050 .469"/.477" 110 lsa
700r4 trans stock converter
2.73 rear (3.23 in future)
goin in 90 camaro
now, unlike most, i am not building for the most power. i'm not trying to hit 500hp, 10 sec, or anything close. actually, if i hit 325hp i'd be happy! what i am going for is more of a daily driver/highway cruiser with just a little attitude. not interested in turning high rpm's. i'm not goin to cage the car or use subframe connectors. it's a ttop car. being built as a backyard show car. something that looks nice, drives great, yet has just enough to be fun at the track once in awhile.
so...heads. not interested in the vortecs. yes they are great heads. but where i live they are non existent. no shops here want to touch them. and i can't stand the centerbolt VC's. with the cam i have i would need to work the guides for clearance, bigger springs etc etc. really don't want to put that kind of money into heads. i'm also hesistant about the 64cc. i am not going for high CR. my goal is 9.5:1 or so. i've punched the numbers into a hundred CR calculators with a hundred results from 8.9:1 up to 11.21:1
most everything i've read is about building the highest power. not the direction i want to go. so what seems to be a good head? i really don't care about the chamber size. it could be 76cc just as long as it works great. i have a line on a set of early 416's with 1.94 valves cut in, and 64cc. or should i find a set of 76cc with 1.94's?
Old 02-09-2013, 08:43 AM
With XE262H, Vortec heads might not be a bad idea. Stock springs work fine with that cam as long as you stick with the 1.5:1 rocker ratio. I like to see the rotators removed and new springs installed, to get the most out of the new cam.
Dart Iron Eagles are excellent performers, but may be a bit large. If you can find some World "SR Torquers", they're what you want for the torque. If you want to stay with Chevy castings and steer away from the Vortecs, the 441 (last three digits), 993, 997, 487 are all good castings to work with. They have 76 CC chambers (nominal) making them ideal for pump gas.
FWIW
Jim
Old 02-09-2013, 09:00 AM
i'm not totally dead set against the vortecs. but where i live no shop wants to touch them. they are voodoo around here. i'm not a fan of centerbolt vc but it does seem like they are good. i just can't see spending $600+ for a set of stock vortecs plus shipping. did find couple shops that'll rework them but they think highly of their work. $250 for full clean/mag/3 angle. which puts me right back to $600+ after i find a junkyard set.
unless someone knows of a KILLER deal online...
Old 02-09-2013, 10:27 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Nobody in the CA Bay area or San Jose will touch Vortecs? Do they say why? I haven't had head work done for ages, but $250 doesn't sound over the top for a reputable shop.
Semper Fi
Old 02-09-2013, 10:31 AM
not living in CA or San Jose. not sure where that came from. live in south central kentucky. there are couple shops that will touch heads but $250 for non 3 angle, basic rebuild is more than i have ever paid. people around here do not use vortecs. even the roundy round guys don't like them. it's really odd, i agree.
Old 02-09-2013, 11:08 AM
Proud LOSER
first. the setup.
goin in 90 camaro
So unless those 416 heads have some heavy deshrouding they are in or around 58cc's, not what your looking for. If your not shooting for big HP, check out Skip Whites pro comp stuff, I would go with 64cc's and a. 041 head gasket, gives you about 9.8 or less comp. The price is under 6bills and they seem to work decent. The problem there is that power is addictive....it won't take long before a couple late night romps, or trips to the track and 325hp will get mundane. Everyone says "nah it won't happen to me" but reality is it usually does, so it's nice to have a head you can grow into. For right around a grand you can do the summit house brand heads, which are brodix, and have room to make far more power then your required 325. Or pro-filers, if you ever want to get real serious they can be opened up a ton. There's lots of choices, but if your serious about budget, and "only" 325hp then the pro comps may be the way to go. He uses his own hardware, and checks his stuff, and warranties if required.
The Following User Says Thank You to bygddy For This Useful Post:
maxxman04 (02-09-2013)
Old 02-09-2013, 11:21 AM
oh, i know all about "the bug". lol. but, this is seriously just a MILD build. the need for speed fix is another project of mine. THAT one will get spared no expense. but for the current build, i'm gonna take it easy. as it turns out, i just made a call, and may have found a deal. going to go check it out. $300 for fresh rebuilt 906's with .525 springs and an rpm intake. still not fully sold on 64cc but i can't be the only one who has used them. and still not a fan of the centerbolt, but maybe it'll grow on me. worst case, i don't like and sell.
i will however keep taking input, just in case this deal is a no go
Old 02-09-2013, 11:58 AM
yea, my past experience with 64cc has been good, but i've used 272 or bigger cams. and having done CR calculators that spit out 11:1 or high 10:1 CR has put me on edge a little. greatly, greatly appreciate all the friendly advice!!!!
Old 02-09-2013, 12:22 PM
thanks for the link!!! ok, so slightly confused. my understanding is the valve reliefs are entered as a positive number, not negative. am i wrong? also, how streetable or lower rpm friendly is 10:1 going to be? with 700r4 and 2.73 i'm afraid it'll be a pinging slug. like i said tho, not looking to build a monster out of this car. already have another one for that. just something with a little kick to it. actually, i guess i could just use a good octane booster every other tank or so to help.
Old 02-09-2013, 12:37 PM
vinniekq2's Avatar
any reason not to use edelbrock E-tecs?
Old 02-09-2013, 02:31 PM
Keep the ports and valves relatively small to make that cam "work" properly. It's not a high rev cam. In a 355, it's all done by about 5,600. Nice low-end and mid-range, though. I wouldn't go any larger than 2.02, and probably "like" 1.94s better. For iron, keep the static ratio in the 9.2-9.5:1 range. For aluminum, 10.2 or so. Some of our happiest small block customers have Edelbrock Performer, an AED 650HO or a nice Q-Jet, that cam, small headers and good ignition. Very torquey, nice rumble to the idle, stock converter, snappy performance "at speed", strong vacuum and reasonable gas mileage.
Yes, valve reliefs are a "negative" as they add to the overall volume. Same as a "dish" or "reverse dome". Deck clearance is also a negative.
FWIW
Jim
Old 02-09-2013, 04:35 PM
You can get new vortec heads from Scoggin dicky chevrolet, already modified for the higher left etc. They deliver them right to your door and no need to involve a local shop. The vortecs are good for a basic build as they create low end torque for a street car. If you use old style sbc heads from the 1960's 9.5 :1 compression may detonate. With vortecs and the newer style chamber you can easily run 9.5 to 1 up to 10:1 without problems if you keep the engine cool with a good fan and radiator (180*) .
The Following User Says Thank You to cadillacdave1 For This Useful Post:
Old 02-09-2013, 06:36 PM
ok, so picked up the reworked 906's. 3 angle, .525" z28 springs, shaved ever so slightly, just to clean up. cc'd in at 63.8. yea, i always go prepared. only thing i'm not sure of is lock to guide clearance. from what i have read and heard i should be ok. but, i might just cut them down anyway, just to be sure.
e-tecs are out because of cost.
by researching, digging deep, and haggling, i've only got a little over a grand into motor so far. that includes block, ALL machine work and balancing, parts, and such. tight budget. quality is still there, but just not the cost.
also did check with SD, and yes, their price wasn't bad at all for what they do, but still out of budget for me.
so, with all the specs plugged in, i get a 10.15:1 motor. which is a little higher than wanted or expected, but not unwelcome. just have to dial in timing just right.
Old 02-09-2013, 07:03 PM
ok, so now here's a question. head gasket choice. it was mentioned using a 4.166 with .041 comp thickness. but in looking at all the choices i have, can i use a thicker, bigger bore gasket? fel pros q1044, 4.200 .051 which would yield a 9.8:1. or is going that large of a bore not good?
Old 02-09-2013, 07:51 PM
wouldn't work then? that's what i was afraid of. 4.166 is the biggest? can i use that bore size only thicker, like .045 or .053? the .053 is probably gonna put my squish to high tho.
head bolts or head studs? head gaskets? thefloyd1973 Engine 9 07-04-2008 09:25 AM
head ache. sbc heads excaliberprime Engine 7 03-07-2007 06:03 PM
head (ache) Paul H Engine 9 09-23-2006 10:57 AM
my new head ache bear1980 Engine 8 09-11-2006 09:32 PM
Nothing like pounding on some cheap headers killerformula Engine 5 07-09-2004 05:50 PM
