GOT A Question about an intake! - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-11-2008, 07:28 PM
My question is about my intake. I bout it at a swap meat and was wondering if it mattered what water inlet i used. Its a small block chevy single plain aluminum unit. It has 4 water ports at the corners. Do I just plug the unused ports. Are all water port sizes different or are most the same size, I was wondering if anyone knew the the thread size. I believe that the intake is a professional products Hurricane from the pictures Ive seen. Got it for a mere 10 bucks and it ant warped and dont leak, so I think I did alright dont know much bout them though. Please help if you can. Feel like I should already know this answer HA!
Old 08-12-2008, 08:06 AM
Holder350's Avatar
Auto Parts Professional
any water outlet should fit......the bolt size is 3/8X16
The ports at the corners are for a cooling system that has separate lines running from the front of the intake to the back.
I only use the front ones.....1 for the temp sender and the other for the heater outlet
Old 08-12-2008, 05:15 PM
thanks for the info
Old Holley Intake Question.... HawkZ28 Engine 10 02-28-2011 11:19 PM
intake gasket question thefloyd1973 Engine 3 05-25-2008 08:26 PM
porting a intake question Jamie Thomas Engine 7 04-11-2008 08:04 AM
carb and intake question hddave1 Engine 12 03-30-2008 10:33 PM
Vortec intake question? crseth Engine 11 12-19-2005 07:25 PM
