got these heads with my block 193 - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-18-2012, 12:22 PM
1996thunderchicken's Avatar
ALL AMERICAN MADE
its a 350 sgi block theads last 3 digits are 193 on both heads so no mix match i know there swirlport heads and that they have the 185 cc intake runner and that there 65 cc chambers i like the heads so im gonna do a lil to em to make em breathe a little easier and able to breathe past 5000 which is there fall on the face mark dont need em for 6000 use maybe 5500 but thats about it daily driver with a lil better maligae and low end torque lol
Old 11-18-2012, 12:44 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
For those of you (like me) who don't know what SGI is, I googled it and found this explanation on answers.com........
"Spheroidal Graphite (Cast) Iron. As the name implies, graphite is present in spheroidal form instead of flakes and compared with Grey Cast Iron it has higher mechanical strength, ductility and increased shock resistance."
I'm always amused when someone says he is going to grind on a set of heads and make them better. If you don't have a PhD in Fluid Dynamics or decades of head porting experience, my best guess is that you'll end up with heads that won't flow any better than stock.....or maybe worse.
You're saying that this is a street driver motor, so bolt it together and go. You'll never use revs past 5000 anyway.
The Following User Says Thank You to techinspector1 For This Useful Post:
68NovaSS (11-18-2012)
Old 11-18-2012, 01:17 PM
ALL AMERICAN MADE
i wasnt saying i was gonna grind em i was just going to do a home pocket port and then have the machine man in town surface them so i know they are flat surfaced not wanting to go over board beleive me dont have enough dough to go full on lol
193 heads, best cam. Bogger Engine 34 10-21-2012 09:55 PM
Chevy #193 heads....Your thoughts.. 8843astro Engine 12 05-10-2009 11:56 PM
193 swirl ports any good???? eatonde Engine 13 11-01-2008 02:29 AM
193 vs 882 heads Warrant Engine 18 12-22-2006 09:50 PM
