-   Garage - Tools (http://www.hotrodders.com/forum/garage-tools/)
-   -   Gouging with a Miller Syncrowave 250 (http://www.hotrodders.com/forum/gouging-miller-syncrowave-250-a-213560.html)
jonahb 01-29-2012 05:11 PM
Hello everybody,
It has been a while since I last posted but I got a quick question. I am going to upgrade my stick welder to a Syncrowave 250. This machine will be used for stick and gouging for now and later it will be outfitter with an tig torch. My question is that this is an transformer based machine will the internals (like pre/post flow, slope, etc) be able to handle the abuse a gouger will put on the machine. I am planing to use a 1/4 inch carbon rod at about 250-275 amps. I am not planning to run it all day like that because of the duty cycle will not handle it and I do not believe that I would be doing that much gouging. The most gouging I would do is wear bars/ shanks/cutting edges / and ears which shouldn't be too serious.
TexasT 01-29-2012 06:01 PM
You might look into some 1/8" gouging rods. Great for more control and more intricate work. The quarter is great for big things, but clumsy when detail is in order.
jonahb 01-29-2012 07:41 PM
Thanks for the reply, the reason I want to use 1/4 carbons is because most of the fillet welds are 1/4 and 1/2 inch which I believe that the 1/4 should work better. The 1/4 inch is the smallest I can get at my local welding supply and the largest I believe the machine will burn is 3/8.
Old Fool 01-30-2012 07:04 AM
Love the air-arc torch, what a noise! Heat it up and blow it away :D
jonahb 01-31-2012 05:22 PM
I hear you, I love Carbon arc cutting at work, I use 1/2 and 3/4 carbons from 400 to 600 amps (two machines). I don't think I'm going to that scale at home though. :spank:
