Gov lock reaplacing with.....? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2010, 05:32 PM
454headache's Avatar
Surprise surprise, the gov-lock in my rear end is a piece of garbage. It has been reliable though, in that it reliably gives me a one tire fire time after time. So I want to replace it with something else....
My question is can I just buy say an auburn lsd or Detroit locker, etc and replace the gov-lock with that? Is it as simple as that sounds? Or will I have to take out the ring and pinion, set lash, etc?
This is a GM 14 bolt 9.5" 3.73 rear end.
Old 10-27-2010, 05:43 PM
big gear head's Avatar
High Performance Rear Ends
Eaton makes a very nice Posi for that rear end. It would be a much better differentuial. Don't get an Auburn.
Chances are that the gear on the governor is broke. That's the most comon failure of the Gov Lock.
Broken teeth on the governor and cam.
You can't just remove one differential and stick another one in. You must measure your bcaklash before you remove the old one and then set the backlash and bearing preload again when you install the new one. http://www.nastyz28.com/forum/showth...t=install+posi
Old 10-28-2010, 11:58 AM
Overdriv's Avatar
Just about anything would be better than a Gov-Loc, but my pick would be the Eaton or the Tru-trac.
Old 10-28-2010, 07:49 PM
1984 C-10 383 SBC
Eaton Posi Unit.
replacing gov lock in 8.5 S10 rear matt167 Transmission - Rearend 10 04-02-2010 10:29 AM
700r4 lock up confusion jrs22166 Transmission - Rearend 4 07-28-2009 09:35 AM
? Eaton G80 Gov Lock diff in GM trucks ? xntrik Transmission - Rearend 16 06-28-2007 01:01 PM
HELP, Gov Lock Differential B-210 Transmission - Rearend 4 05-12-2005 07:34 PM
