Govener recal on TH350? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2010, 07:27 PM
Madmax305's Avatar
I just installed a transgo shift recal kit on my th350 and I am pleased with the results, however I would like the shifts to be even more crisp. I put the trans kit in after I installed a 3000 stall. My question is, how difficult would it be to recalibrate the govener? I would have to buy the B & M or tci kit. Could anybody explain how to do this? Are there any pros or cons to this modification....
Old 12-02-2010, 07:12 AM
The governer only has to do with shift timing not firmness. Look at the post on rebuilding the TH-350 on this sight to help find what your after.
Old 12-02-2010, 09:07 AM
runn141's Avatar
SB S10
the 3000 stall converter is probably softening the shifts, the one i had did.
Old 12-02-2010, 09:55 AM
Madmax305's Avatar
Thanks for the input guys. What I would like to do at this point is to lenghten the shift points of the trans. They seem to be way too soon.
Old 12-02-2010, 11:46 AM
runn141's Avatar
SB S10
is your kickdown cable hooked up?
Old 12-02-2010, 03:29 PM
Madmax305's Avatar
Yes, it is hooked up. When I floor it, sometimes it kicks down and other times it doesn't.
Old 12-02-2010, 05:42 PM
What are you running for a modulator and is it to manifold vacuum?
Old 12-02-2010, 09:25 PM
Madmax305's Avatar
I am using an adjustable b & m modulator and yes, it is attached to a vac manifold port from a holley carb. I have not adjusted the modulator yet, I am not sure which way to adjust it for quicker shifts....
Old 12-03-2010, 03:06 AM
runn141's Avatar
SB S10
turn it in clockwise about a half a turn and see how it is before you do anymore. there should be an adjuster on your kickdown cable.
Old 12-03-2010, 03:18 AM
runn141's Avatar
SB S10
this might help you out. http://www.dragracingonline.com/tech...vi_9-bm-1.html
when i did mine i just disassembled it and ground the weights down smaller. almost an 1/8 inch on each side of the weights. it will shift at 5200 rpm now. cheaper than buying the kit. but the kit has more, i think the lightest weights in the kit will make it shift at 6100 rpm.
Old 12-03-2010, 03:49 AM
sqzbox's Avatar
My pipes are my music
I second that. It seems more and more like instructions for adjustments never make it in the box anymore. Same thing with adjustable vacuum advance cans for a distributor.
Old 12-03-2010, 08:00 AM
When you put the kit in the trans did it supply new gov springs? If so you may wan't to put the old ones back in.
T-350 or T-400 in C10 ekacpuc Transmission - Rearend 2 05-17-2010 02:17 PM
T-350 Rebuild Tech jakeshoe Transmission - Rearend 10 10-05-2008 03:58 PM
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Stock TH350 capacity 307malibu Transmission - Rearend 7 11-01-2007 10:16 AM
TH350 to M21 or TH350 to 700R4 thecamaroguy Transmission - Rearend 6 02-10-2005 01:18 PM
