Grade 8 Bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-17-2010, 02:35 PM
daveh's Avatar
Grade 8 Bolts
Hi guys is there any bolts that are stronger than a grade 8? Thanks
Dave
Old 02-17-2010, 03:00 PM
ericnova72's Avatar
More for Less Racer
Yes, lots of the Aerospace grade stuff is better than Grade 8. ARP has several lines of automotive fasteners better than Grade 8 - 8740 alloy, ARP 2000 alloy, and L19 come to mind.
Old 02-17-2010, 03:14 PM
cucumber1949's Avatar
T-Bucket, Corvette, Mustang
What do you want to use them for?
Old 02-17-2010, 04:00 PM
daveh's Avatar
The bolt on my rear brake assembly that holds the strut in place on my 2001 Sable snaped off when I was removing it. So I drilled it out and I am going to install a nut and bolt and I want the strongest I can get to put in there because of the weight. Do you have any suggestions? Thanks
Dave
Old 02-17-2010, 04:13 PM
For some good place to start on chassis fastener info, go to the CoastFab.com website and click on the tech info link. Grade 8 may not be the best for bolts that are in a shear load application - Coast Fab indicates that AN aircraft hardware is 'vastly superior' to Grade 8 bolt in a shear load. AN hardware is actually rated equivalent to Grade 5. Grade 8 is 150,000 psi tensile and 90,000 psi shear, Grade 5 is 125,000 tensile and 75,000 shear.
In any event, they have a load of info on all kinds of bolts nuts and washers and their application. They'll also send you their catalog which has all the tech stuff inside as well.
Old 02-17-2010, 07:23 PM
techinspector1's Avatar
Wiki Edits: 326
Just so you know, the best source of Grade 8 hardware of all kinds is in the parts department of your local Caterpillar dealer.
Stainless Steel Engine bolts? zbhover Engine 21 10-14-2008 09:27 PM
ARP head bolts oldred Engine 4 04-01-2005 11:32 AM
"Bowed" deck lid cruzinTLT Body - Exterior 3 03-04-2005 10:24 PM
body parts fitting anyoldchevy Body - Exterior 10 02-20-2005 10:20 AM
Removing fenders? Jag Daddy Body - Exterior 3 11-26-2003 05:42 AM
