Hotrodders Bulletin Board > Tech Help> General Rodding Tech
Register now (free) or login to remove ads
Thread Tools Search this Thread share on Facebook
  #1
Old 11-23-2005, 02:46 PM
deathbypontiac's Avatar
deathbypontiac deathbypontiac is offline
New Member
Grade of weld nut
I am getting ready to weld some nuts for body-mounts ETC before boxing my rails and was wondering what grade of nut to get. will any cheap nut work or grade 5 or 8.
  #2
Old 11-23-2005, 03:28 PM
Rob Keller's Avatar
Rob Keller Rob Keller is offline
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
think about it...... do you want to take a chance later when its all done and have a failure do to useing a non graded home depot nut??
go 5 for normal stuff and 8 for heavy and make sure to use a bolt in the nut while welding for shape and to keep slag out
good luck
SR66
"SlowRide66"
"Illegitimis non carborundum"
Crankshaft Coalition Master List of Hotrodding Forums
Old 11-23-2005, 04:12 PM
Henry Highrise's Avatar
Henry Highrise Henry Highrise is offline
Lost in the 60's
Wiki Edits: 4
What Rob said...plus remember that the grade numbers designate hardness as well as tensile strength. So do not try to cool them with anything after you weld...let them air cool so you will not lose any temper.
Old 11-23-2005, 05:23 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
Check around for an industrial fastener supplier as they do make nut plates for that sort of application..works a lot better than welding a nut in place..
OMT
Old 11-23-2005, 06:45 PM
61bone 61bone is offline
Last journal entry: frame build
When welding nuts, i use a piece of threaded carbon rod( available at your welding supply house in various sizes) to keep the threads clean. As welding the nut will shrink it some, you need to run a tap in them to resize the thread. Cage nuts are a better solution if there is some access to the back side. If not, I would use a Rivet nut. If things go bad, they can be knocked out and replaced from the outside. The fancy tool is nice, but not necessary. They can be set with a bolt and airwrench or just plain wrench.
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "Grade of weld nut"
ThreadThread StarterForumRepliesLast Post
Welding infoKevin45Body - Exterior1008-26-2011 09:09 AM
"Basic of Basics" Welding - How do I repair body panels?CenterlineBody - Exterior2906-18-2009 07:54 AM
"Basics of Basics" Sectioning a BodyMARTINSRBody - Exterior711-24-2008 01:04 PM
Question on Mig Welding - HOW tomodasBody - Exterior4312-31-2005 10:48 PM
Welding BooksMagnus_JagerGeneral Rodding Tech611-29-2005 04:57 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
