Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Gram Scale Suggestions for weight matching pistons
Old 11-16-2012, 03:05 PM
zildjian4life218's Avatar
zildjian4life218 zildjian4life218 is offline
Listen and Learn
Last wiki edit: DIY junkyard electrical fan controller
Last journal entry: SBC 305 Twin Turbo
Wiki Edits: 7
Originally Posted by cobalt327 View Post
I have three gram weight scales I use for fireworks making, so I can give you a couple tips.
Be sure the platform that will receive the objects to be weighed is large enough that the weighed item doesn't obstruct the display.
Be sure the accuracy is within your needs. I would think +/- 0.1 gram would be about right. My smallest scale is accurate to 0.01g (10mg), but the total capacity is too small for what you're doing. I use it mostly for test batches of fireworks compositions and reloading.
They all seem to have an auto-off feature. I find that frustrating; on one of my scales every time I turn around it seems, the damn thing has shut down. The length of time until auto off is not usually published, either. So keep a pencil and pad handy and write things down.
I have Ohaus and chinese scales and the accuracy is within the published range for them all. One chinese scale has been used for about 8 years now on a fairly regular basis (came from HF), no probs. So depending on your budget, buying a cheaper scale isn't necessarily sacrificing accuracy.
Get a set of calibration weights and use them.
The smallest scales do not have the option to use an AC adapter. In your case you might want to go w/one that has that option. An adapter or batteries can be used on most all of the larger capacity scales like the one below (I own one of these, BTW):
Digital ScaleThe resolution is 1g on this scale, has a 40 second idle time before auto off. I use it for bulk chemicals. You might want better resolution. Generally better resolution means less capacity or more money.
Really homemade fireworks? That's fricken awesome lol. I live around the corner from a harbor freight so maybe I will stop in later and check out the scale. How critical is it to have the hanging point of the small end and big end to be parallel? I noticed that in the video the scale and rod hanger are all on the same piece of metal. I imagine this is critical as well
