gran torino- Pinking - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-15-2003, 05:45 PM
gran torino- Pinging
i have a 1972 ford gran torino, which i have recently purchased ,it has a 351clevland 2bbl which seems to be pinging under load, it seems to be running quite hot as well, i have heard that maybe removing the air con equipment may help it to run cooler, then also i guess it may be that the timing is out , so any help on this matter would be much appreciated, thanks
Old 09-15-2003, 10:02 PM
Silver_Camaro's Avatar
Superior Wheels Quality Tech
Sounds like the timing needs to be retarted a little... Does the motor kick back when trying to start it? (Hard to crank)
Old 09-15-2003, 10:12 PM
it cranks over great , although when hot it sometimes wont start unless accelerator held fully down, it generally runs really well otherwise
Old 09-15-2003, 10:53 PM
crazy larry's Avatar
Last journal entry: better comparison before and after shots
please forgive me for asking a dumb question but....
are you able to check the timing, ie do you have a timing light? or access to one?
cos thats what it sounds like to me.....
Old 09-16-2003, 05:30 AM
woodz428's Avatar
Troll Hunter
Arrow
Those were in the early era of pollution controls and have several little devices that could affect it. I think it has an egr,they are used to cool combustion temps,might check that it's functioning. If it is the plate type,the early aluminum ones had a bad deterioration problem and would errode away creating a lean condirion that would also cause that.
