Granada Brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-09-2005, 06:11 PM
Granada Brakes
i need to find out how to swap my 1970 mustang to front Granada disk brakes. I cant find info anywere. Please help!
Old 06-10-2005, 12:05 AM
www.corral.net/forums has a section for classic Mustangs. Might search there if you don't get a reply here.
Old 06-10-2005, 01:02 AM
aka Duke of URL
It would be much easier to find a 69/70 MUSTANG/FAIRLANE of the period. Do you actually have the GRANADA swap?
Old 06-10-2005, 01:23 AM
abstruse dutch uncle
http://www.mustangsandmore.com/ubb/D...onversion.html
Outer tie rods, spindles/etc..
Pretty straightforward.
The '68 out back (not mine) is using a '75 Grenada 15/16" master cylinder, with manual brakes. The calipers are also '75 Grenada, having 2 5/8" pistons. I did not do the swap, but I have done some work on the car.
It stops well, but has no prop valve. The rears tend to lock in the rain in a hard stop. It has the 10" rear drums with the larger (15/16") cylinders. I'm fixin' to put the 13/16" cylinders on it.... or maybe I'll just plumb a prop valve
I would think the 1970 should be similar.
The Grenada spindles do move the wheel centerline slightly (forward?) from where it is supposed to be.
Old 06-11-2005, 07:57 PM
i have the disk brakes and most of the parts from the granada but i do not know what master cilyinder to use with it and what brake booster if i do need one... pluss some instruction on how to do it would help...
Old 06-11-2005, 10:12 PM
If you are changing from manual drums to manual disc, I would use the 15/16" Grenada master or a 1970 Mustang 1" master. The 15/16 will be easier to push, but has a bit of travel to it.
If you're changing from power drum to power disc, either one still might work, or you might need to step up to a 1 1/8" bore (ford truck).
The 1970 Mustang calipers are listed as having a smaller piston than the Grenada, so might need a larger master. I know the 15/16 works on a manual-manual swap.
If going from manual to power or vice-versa, I have no idea. I think they used different pedal assemblies.
I also found out the wheelbase change with the Grenada spindles is only on 1965 6cy cars, and it makes it shorter.
I thought the link I gave had decent directions. I just picked one out of the many I found doing a GOOGLE search.
disk brakes conversion no pressure to back brakes shiner Suspension - Brakes - Steering 10 01-24-2011 11:09 AM
63 sub disc brakes or no disc brakes sub63 Suspension - Brakes - Steering 5 03-19-2005 11:31 PM
dropped spindles and granada brakes? flamedfordbronco Suspension - Brakes - Steering 13 02-20-2004 06:06 PM
75-80 granada brakes to 63 fairlane??? 2112jb Suspension - Brakes - Steering 6 08-23-2003 12:49 PM
granada brakes starliner Suspension - Brakes - Steering 2 01-15-2003 07:44 PM
