Granada disc on my 66 Stang
I have about the worst combo for this swap The car was originally an I6 with powersteering and this combo doesn't give you much choice but to change the whole assembly to a manual 8 setup. I have heard of a shop called rareparts.com that make some custom Ti rod ends that are straight bolt ons. Any comments or other ideas would be greatly appreciated! FYI I have a Shelby drop and 620 springs in the build up plan, to support a 351W (if that makes any difference) also the car will not be raced extensively.
Thanks for any guidance, Fred |
I have every Granada disc article ever put on the Web
And the more I search the more confused the issue gets. It get sticky when yuo are dealing with I6 and Stickier with powersteering. I am more concerned with the strength of the I6 steering parts (although they did last 40 years) but I do plan a big power, weight, and tire change.
The I6 spindles are dramatically thinner than the 8's and the tie rod ends are much smaller and lighter. And the Granada spindle has a larger hole for the tie rod end for both applications I think the manual 8 will accept the Granada tie rod with some isssues regarding tie rod length but the Ford made very specific changes with Powersteering setups and having a 6 makes it worse. It's not easy being a Ford fan!
6cyl spindals are 4 lug, thinner and weaker, granada spindals are the same for 8 and 6cyls, they are 5 lug. go to www.diskbrakeswap.com and get the entire kit if your confused. it bolts in and gives you everything you need. you could get everything from a '75-'78 Granada/ Monarch.
You are correct. having seen the G stuff adapted to a six suspension, I do recommend your changing to the heavier V8 suspension components and adding the G stuff. Essentially you are going to replace every piece of the six suspension, front and rear. While you are there do a bump steer adjustment. |
Thanks to all for your input, looks like I will be hunting down some steering parts
Mustangs Plus has a excellent article on the GMV front disc brake conversion, you might want to take a look at it. http://www.mustangsplus.com/tech/index.htm
I know that you will have to convert your suspension over to V8 components as the I-6 stuff is not compatable with the GMV parts. I also have had some experience with converting Granada parts onto a Mustang, you might want to also read this. 1970 Mustang Suspension Question http://www.mustangsplus.com/tech/index.htm |
Mustang conversion
I did this swap on my son's 66 Mustang I-6 and had no problems. The donor car was a 78 Granada. Bought all new components to rebuild the steering system. Bought rebuilt calipers with the pads included along with new rotors. So...I only used the Granada spindles. I also did the "Shelby" a-arm move and all works well. The only problem I had was finding a shop that knew how to align a car that old. It took two shops a total of four tries to get it right but it works great now.
While I was at it, I switched the rear axle over to a V-8 version for the bigger brakes. Before you go to all of this trouble however, you might want to check out some of the rack and pinion conversions available. I hear some of them are pretty slick. |
tie rod adapters
Mustang Steve sells tie rod to spindle adapters. His discussion board folks are very knowledgable, specializing in classic Mustangs. You really should go all v8 stuff, the 6cyl steering components are pretty light.
I find it interesting how so many people lower the upper control arm "a-la- Shelby" but ignore the other changes Shelby made to the steering to make the cars handle correctly.
It is not a secret modifcation, it's just that people chose to ignore it. |
| Dent Repair | Randy Ferguson | Body - Exterior | 25 | 11-26-2005 09:00 PM |
| Hotrodders Knowledge Cluster: Disc Brake Conversions | Jon | Suspension - Brakes - Steering | 0 | 08-29-2003 03:34 PM |
| Disc Brake Converstion on my 66 Impala | trick66 | Suspension - Brakes - Steering | 1 | 03-23-2003 03:14 PM |
| please need help w/ 66 stang brake swap | ping001 | Suspension - Brakes - Steering | 1 | 03-26-2002 09:29 PM |
| 66 stang project car | ping001 | Engine | 1 | 02-01-2002 03:49 PM |
