Granada spindles on m2 control arms - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-30-2004, 01:48 PM
I bought a set of mustang 11 lower and upper control arms and it has 11 inch rotors and what appears to be Granada spindles(rear steer).can this be done?
Old 12-02-2004, 01:16 PM
Max Keith's Avatar
spindles
That would depend on the year of Granada. Later models had rack and pinion steering, so its intirely possible that they both used the same spindle.
An easy way to find out is to go to a parts house and check on the part number for the 80's Granadas with front steer, and compare it with the part number for your Mustang II. If its the same part number, you are good to go. If they dont match up, take your spindles back to whomever you got them from.
