grand am - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-07-2010, 01:37 PM
grand am
have a 98 grand am . wont start the injectors arent working . starter wore out changed that now it wont start not getting fuel threw the injectors fuel pump is working fuses seem good .any ideas would be greatly appreciated. thanks
Old 06-08-2010, 08:40 PM
DOCTOR DC's Avatar
NUCKINFUTS MOTORSPORTS
Check Your Fuel Pressure.should Be About 55 Psi. Won't Start With Less.
Old 06-11-2010, 12:21 AM
fast68's Avatar
likes chevy trucks & boobies
if FP is fine then make sure security system isnt preventing start
its a common problme on these years of the achievas and grand amssss
i own one and it was same issue
i snipped the small yellow wire coming from the pass key thingy on the lock cylinder in the column
easy to do, just remove column cover real quick and snip the yellow wire, of the three small wires coming out of the cylinder pass lock thingy
then it will always start and the security light will be lit up all the time but oh well.... put black tape over it
common issue with these cars and others too all through the 90s years
seen it a thousand times....
we spent 400 bucks trying to have the ICM rebuilt which is where the security controller is located in these cars and all to no avail, security system still malfunctioned and prevented starts,
cutting the wire works well, been great for over a year now,
if fuel pressure is good and are injecting fuel(clicking sounds if you listen to them with a stick on your ear on them)and if spark is good then its not the security system.
try cam sensor then
thats next most common failure on these if no start or run
fuel pump is number one
does it run for a few seconds when key is put in run position?
for sure?
if so then id vote for ignition or security issue
if it has remote start system then check wiring and connections
also fuses check them all regardless of what else you try.,
ECM one may be burnt
dumber things happen.....
does the CEL light come on with key in run position but engine not running?
if not then thats not good....
check fuses and wiring and fuseable links
