grand national 8.5 ' gears ' - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-01-2013, 06:05 PM
sscanrun's Avatar
Are their any interchangeable gears that would fit a grand national 8.5 ?
Old 01-01-2013, 06:40 PM
big gear head's Avatar
High Performance Rear Ends
Yes, there are a lot of gears that will fit that rear end. It's the corporate 8.5 that was used in many GM cars and trucks from '71 and up. There are gear ratios from 2.41 to 5.13 for the 8.5. You can also upgrade it from 28 spline to 30 spline axles with a 30 spline Eaton Posi and after market axles.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-10-2013)
Old 01-01-2013, 09:03 PM
sscanrun's Avatar
I'm just looking for a 3:42
Old 01-01-2013, 09:06 PM
That's the most comon gear for the 8.5. They were installed in about a million GM 1/2 ton trucks from '81 up and many second gen Z28s.
The Following 2 Users Say Thank You to big gear head For This Useful Post:
Crosley (05-10-2013), sscanrun (01-01-2013)
Old 01-01-2013, 09:31 PM
sscanrun's Avatar
What's the easiest car too find
Old 01-01-2013, 10:49 PM
sscanrun's Avatar
Old 01-02-2013, 06:53 AM
GM 1/2 ton trucks with the GU6 code from '82 and up.
Old 01-02-2013, 02:28 PM
Banned
what gear in it now??
if the g.n was pre 2004r it might be 342
Old 01-03-2013, 07:03 PM
sscanrun's Avatar
I got the rear end from a Guy he said it was a 390
Old 01-05-2013, 04:09 PM
TexasT's Avatar
Did you ever wonder?
Last journal entry: A little follow up
did you take the cover off and count the teeth or look for the stamp that would tell you, or turn the drum and count the yoke revolutions?
You could already have 3.42 and not know it.
'87 Buick Grand National RebelWithoutACause Hotrodding Basics 4 04-12-2011 10:00 AM
1938 Grand National trees Hotrodders' Lounge 2 08-15-2010 01:59 AM
Grand National Rear casper12f Body - Exterior 1 02-05-2008 10:39 AM
1050+hp Grand National Blazin72 Hotrodders' Lounge 3 01-06-2007 06:47 AM
86 Grand National Hoyt Engine 7 06-11-2003 06:47 PM
