Grand National Rear End - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2010, 06:58 PM
McSS86's Avatar
Hey Hotrodders im about to buy a grand national rear end and i would like to know how can i tell the difference? Plz help
Old 08-23-2010, 07:52 PM
big gear head's Avatar
High Performance Rear Ends
The GN had the 8.5 10 bolt. As far as I know they all had the Traction Lock differnetial and 3.42 gears. They all had 28 spline axles. I think they also had the odd shaped housing ends with the three bolts holding the backing plates on instead of 4 bolts like the older 8.5 rear ends. It will be about 58 inches wide. All of the other 8.5 rear ends will be much wider than this.
Old 08-23-2010, 10:41 PM
SSedan64's Avatar
7.5" to 8.5" Diff ID
7.5" to 8.5" Diff ID>> http://dyeager535.topcities.com/diffid.html
Old 08-31-2010, 10:34 PM
McSS86's Avatar
Differential
How can I tell a grand national rear end.?
Old 08-31-2010, 10:56 PM
Crosley's Avatar
Wiki Edits: 1659
Mcss86... I merged your new thread with your old thread since you ask the same question again
Old 08-31-2010, 11:18 PM
SSedan64's Avatar
The code on the axle tube will indicate if it's from a GN, T-Type etc..
http://www.gnttype.org/numbers/axcodes.html
Code location>> http://tech.oldsgmail.com/axle_useage.php
RE: GM rear end Christmas gift request iceman36 Suspension - Brakes - Steering 1 12-06-2009 05:44 PM
Swapping '73-'77 A-body rear end into a '71, & related questions? BinderDriver Transmission - Rearend 3 12-14-2008 01:40 PM
questions about rear end mounting purch modification Riley Transmission - Rearend 7 08-09-2008 08:04 PM
Narrowing a 9" ford rear end powerrodsmike Suspension - Brakes - Steering 6 05-05-2007 12:53 PM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
