Graphite intake gaskets - Sealer or no sealer? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2013, 06:43 PM
I've got these Victor Reinz Nitroseal graphite impregnated intake gaskets for my 347. So, the question is, do I install these things dry or what? There are no specific installation instructions with it, and all the intake manifold install guides I can find are using regular old style Fel-Pro gaskets without any kind of graphite material on them, and they all say to use RTV around the coolant ports. Are graphite gaskets meant to be installed completely free of any sealer? I feel like the graphite would be rendered useless if I covered it with RTV. Gut instinct tells me they're designed to be used dry.
Old 01-17-2013, 07:01 PM
LATECH's Avatar
Run them Dry. RTV on the corners at the intersection of the rails for acros the top of the block.
Graphite is meant to allow the expansion of parts..easily... while maintaining the seal. Especially where the heads are cast Iron and the intake is aluminum, or both are aluminum
Fact is stranger than Fiction
Intake Gasket Sealer - where to coat? Yegster Engine 13 10-06-2014 09:59 AM
Sealer on intake gaskets ? junkyardjeff Engine 3 05-15-2007 11:28 PM
shim head gaskets - sealer ? DHMag Engine 6 05-12-2007 07:49 PM
Sealer on Head Gaskets BringBackTheCamaro Engine 1 02-05-2006 02:10 PM
Epoxy sealer/seam sealer/paint equip Blackdog Body - Exterior 17 10-21-2004 11:19 PM
