gravity bleeding brakes - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-01-2009, 01:41 PM
I am in the process of gravity bleeding my brakes ( 77 corvette ).How long do you let fluid come out or how much fluid to let out.
Old 08-01-2009, 02:04 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
I always open all 4 bleeder screws, and let about a 6" in diameter puddle form.
This way you can tell if the proportioning valve is working. Leave the lid off of the master cylinder, and keep refilling it. Corvettes with 4 wheel disc brakes will empty the master cylinder quickly. Keep topping it off when needed.
Old 08-01-2009, 02:54 PM
T-bucket23's Avatar
Wiki Edits: 26
Generally once you see fluid you are all set, as Carsavycook said you can let it run for a while but don't let the master go dry or you will be starting over.
Did you replace lines or cylinders. If you replaced lines, depending on the configuration a gravity bleed may not be completely successful if the car is level.
Chet
Old 08-01-2009, 06:15 PM
I changed all the lines ,calipers and master cylinder I am getting fluid coming out just was'nt sure how much. Thanks for info.
Gravity bleeding of brakes. BarryK Suspension - Brakes - Steering 25 09-15-2011 05:57 AM
bleeding brakes yragat Suspension - Brakes - Steering 18 07-02-2008 05:32 PM
gravity bleeding brakes and bench bleed pi71 Suspension - Brakes - Steering 2 05-02-2007 05:07 PM
Bleeding brakes (possible bad booster or master?) RippinRon Suspension - Brakes - Steering 2 03-29-2007 06:16 PM
Bleeding brakes Frisco Suspension - Brakes - Steering 4 10-16-2004 02:22 PM
