Thats about the only way you can bleed most Corvettes. Its the only way I can get all of the air out of my streetrod too.
Intriguing, all my years I have never heard of this proceedure. My 34 is real PITA to bleed as it has a master below the floor and four wheel Wilwood cailipers. These calipers each have four bleed screws, two on top and two on bottom. Do I just open the bottom bleeders, or all of them?
Vince |
I would think just the top ones as the air is going to go to the top.
Steve
ince |
the only thing better than gravity bleeding is pressure bleeding.
I used a 1/4" plate with a schrader valve ( like a tire valve) in the middle and a Schwinn tire pump, it has a pressure gauge. I pump it up to about 15 psi and bleed away! Fast too! Wifey is happy to loose that job! |
I have found it works best with a dry system.
After doing major work and all the brake lines are dry I just fill up the res., open the bleeders, and go get a snack and a drink. I check the res. every 15min or so to make sure it doesn't go empty. I normally don't do it that way just because of how long it takes (I vacuum bleed normally) |
Here is a twist on bleeding brakes: vacuum / pressure. I would have trouble alot of times with under the floor M/C cars even with the pressure bleeder and one day after I charged up a new AC system, I thought why not do brakes the same. I put an extra line on my pressure bleeder adapter plate with an inline valve. I purge all of the fluid out of the system. hook a vacuum pump and vacuum jar to the extra line. Evacuate the system down to 20 to 25" vacuum. shut the vacuum valve. The pressure bleeder is hooked to the standard fitting on the adapter plate. I open the pressure bleeder valve slowly and fluid is drawn in to the system, filling the vacuum. I pump the pedal once or twice to seat the pads and I'm done. I don't even open the bleeders. Works great, doesn't waste any fluid if you are doing a brand new system and that pedal is harder than chinese algebra the first time. An added benefit is that you don't take the chance of getting fluid all over a newly painted caliper or suspension part. I have done a few 4 wheel disc cars but no disc/ drum setups yet. I'm not sure that the wheel cylinder seals will seal when I put the vacuum to them. If anyone has any opinion about this, let me know. thanks for reading this,mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example Last edited by powerrodsmike; 02-12-2006 at 01:46 AM. |
I did brake and front end work in tire stores and dealerships for years, taught Mechanics at the high school level for 13 years and Like 302/Z28 have never heard of "gravity bleeding brakes" or seen it performed.
Admittedly the old tried and true "pump and hold it" method doesn't work well on some systems. Pressure bleeding will work most of the time and I have had good luck with the hand vacuum pump system although it is a bit slow. I'm not saying that it won't work in some applications but I can't see it working in the majority of rigs. If you pressure bleed a system I think 25# is the max pressure for most bleeder tanks. If you used the tire valve on a spare mc cap be carefull that you don't run out of fluid or you would be pushing air back into the system. |
I was taught gravity bleeding when first starting out about 20yrs ago. Sometimes it's just about the only thing to get things working when you have no pressure bleeder, esp if your pedal pumper is an idiot. Vacuum bleeders never worked well for me.
Gravity bleeding and vacuum bleeding will not work well with residual valves in the system. I've seen it recommended in old shop manuals for disc brakes as early as 1970, or possibly earlier. |
It also helps to tap on the calipers and wheel cylinders when bleeding
a system for the first time. It releases the tiny air bubbles that stick to the insides! |
I've Owned 7 Older Corvettes...
2-13-06
Only Thing I Can Add After Reading All Great Posts: Older Corvettes Are Famous For Trapping Air At (Between) Dual Master Master Cylinder & Metering Block (Rarely Goes Bad) Causes (Adds To) Problem_ I Ended Up Replace (Metering Block My 1968 Corvette) And Use All Stainless Steel Calipers & Master Cylinders------BUT: Dual Master Cylinder Must Have Dual Bleeders_ I Follow Procedure Bleed Right Rear,Left Rear ,Right Front, Left Front Calipers-- Then Bleed Dual Bleeders Rear 1st, Front 2nd--Making Sure Master Cylinder Fluid Is At Level _ Colder Weather Adds To Above Problems- Corvettes- Calipers Originally Had Plastic Pistons In Them,i.e. Let Air In (Expansion & Contraction) Biggest Reason To Go All Stainless_ Due To and Of EPA Bullsh*t Even Todays Brake Fluids Are Diluted (Made Cheaper) Other Additives,etc.Only Adds To Continuing Problems... Vincent Auto Last edited by Mean@MeanMother.Com; 02-13-2006 at 04:30 PM. Reason: Attachment |
One time I asked an old-timer I knew to help me bleed the drums in my 67 Tempest.... he agreed and showed up... I already had the car on stands.... I asked him to get in and pump 'em up and he just laughed.... he opened the bleeders, filled the master to the brim and said "lets's go get a beer".... we came back three hours later, he closed the bleeders and turned the adjusters in about 1/8 of a turn each.... best pedal feel I ever had in that thing.....
| Brakes locking up in non ABS system | nprfan | Suspension - Brakes - Steering | 9 | 08-24-2005 12:37 PM |
| Problem with Bleeding Brakes | ericgantner | Suspension - Brakes - Steering | 10 | 11-24-2004 05:32 PM |
| Bleeding brakes | Frisco | Suspension - Brakes - Steering | 4 | 10-16-2004 02:22 PM |
| More Bleeding brakes | Screwy Lewy | Suspension - Brakes - Steering | 7 | 06-23-2003 08:05 PM |
| Bleeding Power Disc Brakes | J J Beck | Suspension - Brakes - Steering | 4 | 06-16-2002 11:07 AM |
