grease or what ? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-11-2010, 05:54 PM
grease or what ?
got the old 67 burnt olds painted and what would yo put on the wiper trans arm for lube ?
thought about a drop of Lucas oil treatment . but how often will i need the wipers in a pretty day only cruise .
Name:	may - 2010 092.jpg
ID:	46685   Click image for larger version
Name:	may - 2010 096.jpg
Old 07-11-2010, 10:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I would use a white lithium grease. Best if the joint is disassembled and the copper (brass?) inserts are cleaned and the grease applied, then reassembled.
Pay attention to where the adjustments are at (the joints are slotted for adjustment), they will effect the action if they're not reassembled correctly.
Whats Wrong With Grease Guns ??? Guy Hiltz Hotrodding Basics 26 08-07-2007 05:23 PM
Grease Slung on Floor Pan Above Pinion U-Joint JohnTN Transmission - Rearend 1 10-28-2006 05:13 AM
White grease on piston rings? Jmark Engine 16 04-27-2006 01:41 PM
Grease turning to oil? tblaze General Rodding Tech 2 10-15-2005 06:47 AM
grease in disc hubs?? Maverick Suspension - Brakes - Steering 2 07-22-2002 06:22 PM
