Greaseable U Joints or not? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2013, 01:48 AM
Hey everyone,
Just curious, how strong are the greasable u joints? I was thinking about putting them in my truck, about 420HP + 125HP Nitrous. I'm pretty sure I need the solid ones but was curious how much HP the greasers can handle. I'll probably go with Moog's
Thanks
Old 10-06-2013, 04:18 AM
Banned
depends on what series the u joints are? but I'd run solids in your case,
u joints are short money so replacing non servicable ones every 25-60k depending on how you beat it.
isn't a big deal,
if you launch a boat using this truck, I'd use greasable at least in the rear
Old 10-06-2013, 05:00 AM
Irelands child's Avatar
When I talked to both Inland Empire and Denny's Driveshaft companies about building a driveshaft for my '31, both said that the non-lube type were stronger/better for any modified engine. It is a choice, but u-joints are cheap in comparison to most other driveline parts and I'll just change them out every 2-3 years with another premium piece regardless of mileage.(I ended up with a Denny's driveshaft)
Irelands child
Old 10-06-2013, 07:57 AM
Greg T's Avatar
www.krusinklassics.net
Last time I bought the Spicer greaseless joints they carried a lifetime warranty. Haven't purchased one in a few years now so I can't say if their warranty has changed or not.
Old 10-06-2013, 10:14 AM
vinniekq2's Avatar
I use the Dana U-joints also. I've only ever broken 1 u-joint so far.It had grease fittings.
u-joints studebaker46 Transmission - Rearend 3 07-31-2007 02:40 PM
U-joints montea Transmission - Rearend 6 04-25-2007 02:48 AM
U Joints camaroguy Transmission - Rearend 6 01-16-2006 06:24 PM
u joints 76CHEVC10 Transmission - Rearend 5 11-29-2004 10:40 AM
U-Joints MI2600 Transmission - Rearend 4 11-14-2004 04:34 PM
