I suppose I should know this, but what is the difference between Orange Peel and Urethane peel ?
I notice a lot of Urethane cars that have a material ripple in them and look like the topcoat should be blocked. I was always guessing someone sprayed, sanded and buffed before it totally cured. So.. what is it? Rich |
Orange peel is caused from poor application, urethane peel is inherent to urethane paints and IMO can't be completely prevented. Sometimes it's worse than others and I think percentage of solids has a major influence. I've seen some pretty perfect as sprayed finishes, slick, wet and smooth but they always have some amount of urethane peel. Cutting them out with a block is your only way to remove them. I know some people seem not to notice it at all and others seem to just ignore the fact that they are there, but when they are gone you end up with that nice flat straight finish similar to the old Nitrocellulose Lacquer days. The older medium solid urethanes seemed to be less prone to urethane peel IMO. Maybe it's a result of texture stack up. ??? Bob
Yea. urethane wave is what my old shop teacher used to call it.. im still trying to figure out how those 400 scratches are gonna come out.. but i guess if u sand one panel with 1000 after 400 for quite a while it should come out at some point..
Thanks guys. I plant to block the first coat with 1000 using a block that is fairly rigid. I guess I can see why Barry would use 400 but that does seem darn course !
OK, sounds like the wave I have seen OFTEN is probably Urethane Peel Rich |
If you look at this pic u will see my florescent lights and how the edges are wavy.. this kinda shows that urethane paints arent flat.. that was only sanded with 2000 grit and buffed.
I don't think you'll be able to see those 400 scratches during the sanding process. Only after you buff. I know Barry knows what he is doing, but I don't know how this is done successfully. However, I only tried this on SS urethane. Could clear be different? |
One option is to start with a coarse grit and block by hand then switch over to a DA with finer grit and sand until all of the straight scratches are gone, this way you know the coarse grit scratches have been removed.
Or change sanding direction. If you use an extremely flat and rigid block and only apply one thickness of paper to it (not wrap the paper around and around) you can get some really good results with 1000 or 1200 on the initial cut. 1/4" thick plexiglass is ideal and can be sanded completely flat with rounded edges and corners, I've got a few of these made up in different sizes that I use for colorsanding. |
i will usually block with 800 first but use self adhesive paper on a ridgid block. i find if you dont use stick it paper the suction from the water just pulls the paper to the paint surface and rides the waves so to speak.
Bump.. I would like to know what kind of paper too... Are you using DA paper?? Never thought about the paper moving aound... good post
BK |
Ive used regular 3m wet/dry sheets and cut them to size and used 3m spray adhesive to hold it to the block. thats prolly the easiest way
The 400 wet will come right out with the finner grits of paper.
My sons Dark blue Corba deck lid with three coats of clear I first sanded with a 320 da to get rid of all imperfections as there is no hiding anything on this car. Then went to finer wet sanding grits and buffed, it buffed great and is slick as can be. This car was done in a way I don't like to do but were under the gun time wise. I don't like the idea of more than three coats of clear a day and I would like to have wet sanded and re-cleared and I would have liked to let the base set overnight. I feel like Boyd but did not have a choice. |
| Great Truths | Weimer | Hotrodders' Lounge | 3 | 10-30-2004 08:25 AM |
| A Truly GREAT and MOMENTOUS Day in Ohio!!! Yay!!! | Native Gearhead | Hotrodders' Lounge | 81 | 01-16-2004 03:09 PM |
| another great day!!! | crazy larry | Hotrodders' Lounge | 10 | 01-08-2004 08:08 AM |
| My first day at WORK! | Rubberman2003 | Hotrodders' Lounge | 4 | 12-27-2003 08:51 PM |
| Qjets Ain't they great | Mertz | Engine | 18 | 08-16-2002 12:53 PM |
