Finally got my truck and opened the hood to find a Chevy 400 Small block! Next question is, I have read about 50/50 split on likes and dislikes, anyone with experience please weigh in. I also heard about cooling problems with the siamesed heads, but also heard that it is solved by having heads with steam holes drilled. Any experiences there? Thanks!
Zak
This is what I found on the net:
BLOCK # 330817
4.125 in bore family (1970–1980)
400
The only block of this family, 400 cu in (6.6 L) small-block, was introduced in 1970 and produced for 10 years. It was loosely based on the medium journal 350 and had a 4.125-inch (104.8 mm) bore and a 3.75-inch (95.3 mm) stroke. The 400 differed from other small blocks in that the cylinders were siamesed, used a 2.65” large journal, and oftentimes had one more freeze plug on both the left and right sides of the block. Initial output was 265 hp (198 kW) and was only available equipped with a 2-barrel carburetor. In 1974 a 4-barrel version of the 400 was introduced, while the 2-barrel version stopped production in 1975. 1976 was the last year that the 400 was used in a Chevrolet Passenger car, available in both A-Body and B-Body lines. While popular with circle-track racers and drag racers, the engine was prone to cooling troubles if cylinder heads without steam holes were used.
Zak
BLOCK # 330817
400
