Great wiring resource found - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-09-2004, 10:57 AM
302 Z28's Avatar
Ran across this while searching for some wiring diagrams. I thought it was worth sharing, hope it's of some help.
http://www.autoshop101.com/forms/allinone.pdf
Backspace to the base web address and there are great links there also.
Vince
Old 07-10-2004, 11:02 AM
TooMany2count's Avatar
A Half Crippled Old SOB....
Last wiki edit: GM RPO build codes Last photo:
Location: Cahokia,IL..... Donate Blood Products & Sign your DONORS CARD
Wiki Edits: 5
here's another one too...........
first off I can't believe I'm even looking at a Auto Zone site...I hate the place(sorry if ya work there), but anyway I was told they had wiring harness diagrams so I looked & low & behold they did(one of the 1st things I like about the place) soooooo here ya go....joe
http://www1.autozone.com/servlet/UiB...3d8012b267.jsp
if the link doesn't work go to http://www.autozone.com/servlet/UiBr...n=viewHomePage & become a member. enter your info on your truck or car, then click on "Repair Info" then on "Vehicle Repair Guides" then on "Chassis Electrical" this should then take you to the wiring diagrams....joe
_________________
Old 07-14-2004, 07:19 AM
My dad is rebuilding a 50 chevy p/u and is in the process of wiring the charging system. Can someone describe how the wiring should be using a generator. There are two posts on the gen. I assume one of them has to go to the voltage regulator but other than that I'm not totally sure. Thanks in advance.
