Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - green stuff on weld
Old 09-28-2006, 05:37 PM
oldred oldred is offline
Should be easy enough to determine if the weld is strong enough but that's a good point anyway. Grouch, I just noticed that you said you were welding outside (I am kind of slow today ) and if that's going to be the case just keep your head out of the fumes and you should be in fine shape. Does that pipe seem softer than the other one? How about when you grind on it, any difference in the sparks?
