to grind or not to grind crank - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-11-2002, 10:29 PM
Post to grind or not to grind crank
I'm looking at buying a 73 454 with 58K original miles on it. However, it has a spun main bearing suposedly. Is it better to grind all the main journals the same for good balance, or get oversized bearing? How could this bearing spin with such low miles? Abused maybe? Thanks, Bill
Old 09-12-2002, 04:40 AM
woodz428's Avatar
Troll Hunter
Post
any time you grind a crank all sets ( mains or rods) should be ground the same more for uniformity and consistant clearance. If you grind a singular journal it could get wasted because the oil clearances in the uncut ones may be looser allowing oil pressure to bleed off through them and starving the newly ground one. If you spin a bearing, rod or main, most likely the main or rod caps are too loose, that's why the bearing spins instead of hammering.Many times people say a bearing has spun before they disassemble an engine, when it's typical bearing failure from lack of oil.
Old 08-20-2009, 06:31 PM
diamond mike's Avatar
throw me under the bus agian
bearings
thats exactly what happened to mine, the guy i bought it off forgot to add the oil after a change and spun its bearings( dumb a--)
