To grind or not to grind? Roller Rocker Q: - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-19-2007, 12:43 PM
dirtydave's Avatar
Well gents,
I like to follow up on my problem when I come to a solution in case anyone else runs into this.
I ordered a set of Crane Gold Race Rockers that were "clearanced for valve spring diameters up to 1.630" "
Guess what? They didn't fit. I got about .030" clearance between the rocker and spring. .040" is usually required. Plus the rocker nut hit the slot of the rocker arm when I rotated the engine. Not good.
So I did some research and ended up going to a stainless shaft rocker system from Crower. It cost $1200. It seemed like a lot of money but after adding up the cost of new rockers, studs, guideplates, taller valve covers and a stud girdle it really isn't that much more. Plus a shaft system will increase the life of the valve train from more control. I was also able to use the same size pushrods I had and that saved me even more money.
Be advised that I still had to use -.050" valve locks to bring the spring down a bit.
So the moral of the story is, when going to a longer valve, don't get anything longer than necessary otherwise you will have a headache to deal with.
Thanks for all of your help and input.
Dave
Roller Rocker issue BuddyK Engine 8 05-30-2007 12:08 PM
SBC Roller Rocker Questions Houston54 Engine 3 12-04-2006 11:37 PM
1.7 ratio roller rocker on a SBC 383vette Engine 1 10-15-2003 10:15 AM
roller rocker / madmax Engine 1 11-17-2002 06:49 PM
STOCK VS ROLLER ROCKER ARMS?????? GONZALEZ Hotrodders' Lounge 7 06-18-2002 10:55 AM
