Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To grind or not to grind? Roller Rocker Q:
Old 08-16-2007, 06:49 PM
Jmark's Avatar
Jmark Jmark is offline
Originally Posted by sam-missle
hi dirty dave, nice pics, only problem is your rockers will never be in the position you have them in in the pics. it looks like once you set the rockers in the proper position minimal clearancing will be needed. it is o.k. to grind for clearance. sam-missle
Good call! If you raise the rockers up to about their "normal" position, the interference may end up a non-issue. A stock pushrod under it will get you close to finding out if you need to clearance the rockers or not.
