Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To grind or not to grind? Roller Rocker Q:
Old 08-16-2007, 10:16 PM
hotrodf1's Avatar
hotrodf1 hotrodf1 is offline
Chasing dreams with a ball bat
Originally Posted by Jmark
Good call! If you raise the rockers up to about their "normal" position, the interference may end up a non-issue. A stock pushrod under it will get you close to finding out if you need to clearance the rockers or not.
I think he said he couldn't even get some of the rockers onto the stud because the interference prevented it. He either has to clearance the rockers or get different rockers I believe.
