Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To grind or not to grind? Roller Rocker Q:
Old 08-17-2007, 12:38 AM
techinspector1's Avatar
techinspector1 techinspector1 is online now
Wiki Edits: 326
OK, I'll add my take on it. I figure that even Comp Pro Magnums don't have superfluous material in them that can be ground away. In the super-competitive environment of speed parts, it is doubtful that the engineers would have designed them with any more material than was absolutely necessary to do the job. Call Comp and find out if there is some other rocker that you don't know about that can be used in this application. If not, ask about using the beehives like the Deputy mentioned.
