Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To grind or not to grind? Roller Rocker Q:
Old 08-17-2007, 09:41 PM
dirtydave's Avatar
dirtydave dirtydave is offline
You're right Mudbogger. 2" is high but required for my high lift, roller cam setup. My cam grinder recommended 240# on the seat from a spring. In order to get that force and to be out of coil bind range with my lift setup, I had to go to a taller install height. (which is helping cause this problem because the taller the valve gets the closer it is to the rocker arm stud since they aren't at the same angle)
