Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - To grind or not to grind? Roller Rocker Q:
Old 08-18-2007, 11:04 AM
383silverado's Avatar
383silverado 383silverado is offline
Originally Posted by 1BAD80
How doe's the gap look with push-rods installed.
The rockers do not go down that far.
A longer push-rod does help most that hit.
Show some pictures with the rods installed, I dought there will be a problem.
have you tried installing a push rod like 1bad80 suggested ?
